![]() | Home > Off Topic > Eastenders's FFRR |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7916 ![]() ![]() ![]() |
Looks like Phil Mitchell has finally found the guy who sold him that 57 plate early ff and told him it was a facelift car
Martyn Member Since: 10 Mar 2013 Location: Poole Posts: 65 ![]() ![]() |
That's not as good as the 60 plate pre-facelift L322 in Fast and the Furious 6 |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1754 ![]() ![]() ![]() |
I assume that Eastenders is filmed on private roads.?
Lad Member Since: 12 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
Those plates don't relate to any car. I think most that you see on tv like that don't |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
Well it's no longer a problem after tonight's episode.
How on earth they have managed to get that sideways I don't know 😂
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Aside from TV plates, you can also get ex-MOD vehicles with later plates on. ![]() Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
How the feck did they get the standard system to do that! Most ff handbrakes couldn't do that I bet, especially on a pre facelift and when the tears lock up the fronts would start killing off speed very quick as part of the drivetrain. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's Mantec Sump Guard, Rigid Load liner, MY10 BT upgrade. ![]() |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Remove and bolt up the front propshaft? Thus making it 2wd? There is nothing that can't be fixed with a hammer😜😜
Surely you'd want to do the rear prop so as not to have to fight it as much although I get the feeling they probably used a hydraulic handbrake to get it to lock that hard and quick. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
You may be right in that. I suspect the car was modded fairly extensively for the stunt, no doubt there would be a roll cage in there too as it was going upside down, so the fittment of an hydraulic handbrake would be logical, they don't play around when doing this kind of thing so £££ would have been spent to make sure the driver didn't get a scratch. There is nothing that can't be fixed with a hammer😜😜
You want RWD to send the rear end out. |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1261 ![]() ![]() ![]() |
The BIG question though is.............
to flip it there was probably an air canon inside too..... just to make sure, as they would have only gotten one take i presume. There is nothing that can't be fixed with a hammer😜😜
