Home > Technical (L322) > HOMELINK
NeinFondue
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Santorini Black
HOMELINK
All,
I have a MY'12 5.0 SC AB which I'm really happy with, however the one thing I have never been able to get working is HOMELINK. I live in a small gated development that has electric gates and electric garage doors. The gates and garage doors are two different systems (2 different fobs), and I can't get either of them working. I have followed the instructions in the manual, and done numerous resets to no avail.. I'm beginning to think that the systems are incompatible, although the fact that both the gate and garage doors don't work is coincidental and likely means it is me that is incompatible Sad
Anyway, any advise is appreciated,,
Post #313667 19th Feb 2015 2:06pm
you're probably doing this anyway but here's a youtube video explaining the procedure,
and,
Post #313668 19th Feb 2015 2:12pm
..and the homelink web page,
http://www.homelink.com/home/welcome ... - .- -.
Post #313669 19th Feb 2015 2:15pm
NeinFondue
That is great Stan thank you.. I'll give them a go this weekend as the one thing I didn't test was the additional steps requited for rolling code systesm..
Post #313671 19th Feb 2015 2:40pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Hi,
I have electric gates on my driveway and have had homelink on my last 6 RR, its a job to get them to work with UK electric gates, i had to get the transponder changed in my gates for the homelink to work but it took a few attempts to get the gate service company to get them to work as the rolling codes need to match the frequency. I tried a hundred times to programme but if the transponder doesn't match you have no chance. Try Chapel Doors in Norfolk they sorted mine so they know what's involved, It wont be cheap to change transponder but its worth it.
Post #313713 19th Feb 2015 5:48pm
NeinFondue
That is my fear... However, I'm going to be optimistic and give it one last try. Sadly if I'm unsuccessful, having the transponders in the gate changed out isn't an option as it is shared and maintained by the management company.. Garage doors on the other hand are my own and I could swap out if required..
Post #313718 19th Feb 2015 5:57pm
Homelink works on old doors and gates provided the frequency is the same , the problem I have found is the new stuff with 2.0+ encryption is too far ahead . I even bought Homelink signal converter from the states to get the system to catch up but no luck so far and I have been trying for a year off and on to make it work . 2008 MY Supercharged
Post #313865 20th Feb 2015 2:03am
RRTIM
United Kingdom 2017 Range Rover Vogue SE SDV8 Causeway Grey
Ours works finr.
1st button does the gates
2nd button does the garage doors
3rd button ejects SWMBO out the sunroof when she moans about me spending too much on cars.
Job done! 2017 Range Rover SDV8 Vogue SE
2018 Audi RS6
2018 VW Amarok V6 255
Post #314792 25th Feb 2015 4:52pm
