![]() | Home > In Car Electronics (L322) > 2009-2012 4.4L L iPhone cable and iPhone 6 compatibility |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
I would like to connect my iPhone 6 to my 2012 L322.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
Apple do a gen 30 pin to lightening adaptor, the problem is the 5 and 6 only output digital stream from the plug on the bottom, so the El cheapo adapters don't have a dac built in hence the 3.5mm jack built in to the cheaper ones. The cheaper ones only function as a data cable adaptor, whether the lr cable takes a digital stream I'm not sure tbh but a fully functional adaptor would be preferable.
RichTDV8 Member Since: 16 May 2010 Location: Berkshire Posts: 54 ![]() ![]() ![]() |
I have gen RR fat plug with gen Apple coverter (£25) sucks when you buy it as £25 for a bit of plastic is dear but it does work and provide full function Previous
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 ![]() ![]() ![]() |
Has this found a solution?
devonchilliman Member Since: 06 Jan 2015 Location: Devon Posts: 348 ![]() ![]() ![]() |
Also interested in any update on this |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
http://www.amazon.co.uk/ViseeO-Tune2air-WM...s=tune2air
Andy, how does it work in relation to the Phone? Do you need to plug one of the boxes into the car & one into the phone? Or does the phone just stream to the one box plugged into the car? |
Hi Craig,
Nice one |
BlackPerth Member Since: 13 May 2008 Location: Brisbane Posts: 114 ![]() ![]() ![]() |
I have the same thing - brilliant and fault free to date. 2017 Range Rover Vogue SE SDV8 (with e-diff)
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 140 ![]() ![]() ![]() |
I also use this Tune2Air from Amazon. It works perfectly and in parallel to the Handsfree Calling functions. |
I have successfully connect my old Ipod Nano to the genuine cable and it works fine.
Slaav Member Since: 02 Mar 2014 Location: GLos Posts: 32 ![]() ![]() |
Chaps, that product doesn't appear to be available anymore...
