![]() | Home > Maintenance & Mods (L322) > Heated Seat. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3879 ![]() ![]() ![]() |
My previous rangie 2007 got the heated seats really hot really quickly .
Ah so my big fat backside maybe is already hot enough |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
Noticed the same Geoff. The 2006 heated really quickly, but the latest takes a while to warm up. On the upside, the heated steering wheel gets toasty much quicker |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8721 ![]() ![]() ![]() |
noticed that too on my replacement nappa wheel, heats really fast. SO hot hands and bum, can't say fairer than that |
Hot hands, cold arse....we all have compromises in life! |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Because the climate seats are air heated and cooled the engine needs warmth to heat your backside. Discovery 4 HSE
Thanks all, obviously patience and RTFM are required. I have a supplementary question for those with later models - when the A/C dial is set to Auto the lights round the dial (fan speed) don't illuminate, they did on my 2007 and the aforementioned manual isn't clear -is this correct? Geoff |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
IIRC Climactic seats are indeed air heated / cooled but the air is blown over a peltier cell to generate heat / cold and is not part of the heater matrix air circuit. |
Maybe you should just go commando |
Conor,
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 ![]() ![]() ![]() |
Yep my 2011 is exactly the same. Assuming thats how it should be. 405 AB exec seats Baltic and Cirrus 93 RR Classic efi Remember it's easier to get forgiveness than permission! Gone in order: 4.4 TDV8 SE - gone to a good home 93 Classic hard dash Plymouth Blue 03 L322 Oslo Blue 2000 Disco TD5 ES Epsom Green 98 P38 Rioja Red 89 Classic Cairngorm Brown |
Having now driven a few miles in Arctic conditions I can confirm that the seat warms up slow and the steering wheel fast.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16329 ![]() ![]() ![]() |
Adam, there is a separate heater/cooler unit for both the backrest and the base... Neither of which has anything to do with the engine temps sir... Geoff, There is an air filter for each unit (4 in total) they are changed as part of a service (can't remember which one at this time of night) So, maybe a blocked air filter? One filter is under the front of both seats (a white foam disc filter) the other one is behind the map pocket in the backrest... |
Interestingly the drivers seat front filter had fell off, just put it back - obviously it was clean as a whistle as it hadn't been filtering. Whilst I was messing about the seat was heated - this is all very puzzling to me |
