Home > In Car Electronics (L322) > Trailer camera
RiccartonRR
Trailer camera
Sorry - this has probably been done before but I can't find anything conclusive so here goes.
I have a TDV8 Vogue 57 plate with the reversing camera - my question is can I somehow fit a camera that'll talk to the screen so I don't have to use a seperate screen for the in trailer camera I use when towing the horses?
Any ideas would be greatly appreciated. Thanks.
Post #287496 19th Oct 2014 10:48am
the OE venture cam was made for this job,..i gather that you havnt got one?
the only other alternative is a separate wireless cam and monitor .. ... - .- -.
Post #287500 19th Oct 2014 10:55am
ebajema
Or the way one of our Aussie members did it, using an old smartphone and suction mount Smile
The venture cam is the "smartest" way IMHO as you can also use it for other stuff like of roading, tight turning etc. MY 2010 5.0 SC Galway green and sand interior!!
Post #287502 19th Oct 2014 10:58am
RiccartonRR
Sounds good - can a venture cam be retof-fitted?
Post #287523 19th Oct 2014 12:26pm
have you looked to see if there is a dock in the upper glove compartment, if there is one then its just a matter of buying the cam..
as for the retro fit, this has been asked before, try a search to find the threads. ... - .- -.
Post #287530 19th Oct 2014 1:29pm
RiccartonRR
Will have a good look - thanks.
Post #287540 19th Oct 2014 3:06pm
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
I have been debating this issue myself but for my caravan although it's more for hitching up than when towing but I could do both. I have a venture cam but don't want to have to keep attaching it every time.
Has anyone tried the wireless cameras that can be picked up on a smart phone?
Something like this http://www.ebay.co.uk/itm/1-3-Cmos-WIFI-in...0010822823
I was wondering if this would work and you could just get it on the phone screen when needed.
Post #287548 19th Oct 2014 3:21pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
Hello,
I fitted a wireless camera from IWT which is assigned to CAM2.
Used to use the venture cam but had the following problems. Suction mount kept falling off - solved by permanent mount.
Camera angle of venture cam not wide enough for front to back viewing, ok for back to front viewing.
The "fitted"camera is a permanent fit with very wide angle looking front to back.
Hope it helps
Post #287663 20th Oct 2014 7:40am
''assigned to cam2'' would this be because you do have the venture cam setup David... ... - .- -.
Post #287667 20th Oct 2014 7:50am
Weegie
David,
Can you also provide a link? John
GAP iiD BT
Post #287674 20th Oct 2014 8:15am
DavidP
Yes i have the venture cam set up for hitching [no trail assist for the fatty] and also if needed, outside the back of trailer when reversing. I find it easier.
Slight problem in giving the IWT link as it always refers me to International distributor, but with the magic of modern internet it's;
http://www.barlowtrailers.co.uk/Wireless_T...stem_B0167
Edit to say the whizz who fitted it had to do something extra (freq) i'll contact him to ask what it was...
Hopefully that helps
further edit - My apologies, its not CAM2 its Channel 2....
Post #287682 20th Oct 2014 9:55am
