Home > Technical (L322) > loss of power / hesitation 3.6 TDV8
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Good evening gents.
I seem to be suffering with an intermittent loss of power / hesitation / additional exhaust smoke on moderate acceleration .
I took it out for a good 25 minute run at 3000rpm just in case it's a build up of crud ( as I only do short journeys these days)
The only code thrown up by the IID tool is a P023D-22(2C) which I've googled and nothing comes up ( anybody know what this is?)
I will be taking a look at the turbo hoses tomorrow, but any other thoughts or ideas on this if that turns up a blank.
TIA.
Paul GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #287448 18th Oct 2014 10:44pm
Mikey
P023D
Manifold absolute pressure � turbocharger/supercharger boost sensor A correlation
Its a zero ( 0 ) , not an O Thumbs Up
Check for split hoses, and turbo actuators for movement/seized rod Thumbs Up
Post #287449 18th Oct 2014 10:48pm
paulmoran2
Cheers Mikey....could it also potentially be related to the EGR's as I know they can be an issue?
P GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #287450 18th Oct 2014 10:50pm
I seem to remember mine had a similar error code and it was a split hose. Got - 2017 SDV8 Autobiography in Loire Blue
Post #287452 18th Oct 2014 11:22pm
Mikey
If it was an EGR issue, it would have logged an EGR code too Thumbs Up
Post #287453 18th Oct 2014 11:23pm
paulmoran2
Sounds positive...fingers crossed for a split hose then...will post the outcome
Cheers gents
Post #287455 18th Oct 2014 11:40pm
Check both top inter cooler hoses, common problem. Happened to mine, have a look in the wiki I did a write up on how to swap one (logical and easy really). There is nothing that can't be fixed with a hammer😜😜
Post #287470 19th Oct 2014 8:08am
paulmoran2
Found it....a 2" split in the right hand Turbo hose!
Followed NMJ's instructions..Removed the offending pipe, cleaned the surfaces, applied the reinforcing tape followed by the Self-Amalgamating tape and refitted...15 mins start to finish. Quite pleased with myself
New hose will be put on order with Ducky Dan tomorrow
Post #287554 19th Oct 2014 4:54pm
Result! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #287556 19th Oct 2014 5:06pm
nice bit of 'first aid' there.. Thumbs Up ... - .- -.
Post #287558 19th Oct 2014 5:07pm
That's the monkey! Should hold fine until the replacement arrives. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #287567 19th Oct 2014 5:58pm
paulmoran2
Cheers for the write up NMJ Bow down
Bet that saved me a good few quid in diagnostics / labour and parts costs...all for a �4.95 pack of hose repair tape Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #287573 19th Oct 2014 6:15pm
Mikey
Result Thumbs Up
Post #287574 19th Oct 2014 6:34pm
paulmoran2
Cheers for the heads-up Mikey...Do you have a list of fault codes we can publish or a link we can post for future use??
Post #287588 19th Oct 2014 7:29pm
Nice cheap fix Paul, wonder how long it would last if you just left it????
Are you going to change them both, can't see the other one being far behind.... or aren't they like radiator hoses and go in pairs??? Pete
Post #287617 19th Oct 2014 8:46pm
