Home > Wheels & Tyres > Fitting wheels
Page 1 of 11 123 ... 91011>
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Fitting wheels
Hello gents, just looking for advice regarding a tool on my wish list...I'll start with a description of the problem as I don't know what the tool I want is called Or if it exists for a FF.
When fitting a wheel onto my FF, the weight and size of the wheel makes it difficult to get It on to the hub centre and align the studs as a one man job. I do however remember having a device for a another car ( that had bolt holes in the hub rather than nuts that go on to threaded studs as per the FF) that looked like a 5" long round rod with a threaded end that you would screw in to one of the wheel nut holes on the hub, then allowed you to slide the wheel on using this protruding rod as a guide in one of the holes on the wheel ( thus supporting the wheel weight and providing alignment)
Hopefully the description is clear enough?...Is there a tool that works in a similar way ?( that would screw over the protruding threaded studs on the hub rather than screwing into the holes as per my other car) and if so, what's it called and where can I get one ( I suppose there are different diameter ones to suit the hole dia on the wheel).
TIA
Paul GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #286714 15th Oct 2014 10:58pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
I know what you are thinking of, but not sure if anything is out there, especially for the FF.
A local engineering company might be able to make something for you, if you explained it to them.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #286716 15th Oct 2014 11:04pm
Sorry Paul, i have not heard of anything like that, that would work on a FF. My advice is practice practice practice sir... Thumbs Up
Post #286717 15th Oct 2014 11:09pm
miggit
Put the wheel on a shovel and use it to leaver the wheel up to the right height, works on lorries! Yesterday I couldn't spell Engineer... Today I are one!
Post #286719 15th Oct 2014 11:19pm
Very good idea Thumbs Up Bow down Thumbs Up
Post #286721 15th Oct 2014 11:27pm
oldcro
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Check Machine Mart site for Dolly Trolleys.
There is one that has two rollers which can be pumped closer together each side of a wheel to raise it, called the "Clarke VPJ300 Vehicle Positioning Jack"
Rather expensive at £107.98 for one but cheaper than suffering a strained back.
I'm thinking of buying one myself as I have the same problems you mention, and saves having to ask someone for help when removing or fitting a heavy wheel.
The Porsche Cayenne has those threaded holes in the hub and comes with a guide rod to screw in
Post #286722 15th Oct 2014 11:35pm
miggit
B&Q shovel under £20 Value Thumbs Up Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #286726 15th Oct 2014 11:49pm
A couple of quick tips if working off the floor... A, don't worry about getting DIRTY! Very important fact... Most injuries occur when you try to hold a wheel away from you to keep clean! & B, roll the wheel onto your foot and use your heal as a pivot point to lift the wheel up & down an inch or two. Thumbs Up
Post #286727 15th Oct 2014 11:49pm
miggit
Just had another thought Shocked you'll not get very far digging yourself out of a snow drift with some wheel dollies Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #286728 15th Oct 2014 11:52pm
miggit
I do the same but use my knee to nudge it up in to place, that way I'm nearer the studs and stand a chance of seeing them Cool
I'm only wearing those glasses cos I'm blind, age is a nasty invention Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #286730 15th Oct 2014 11:57pm
oldcro
Just wait till your old and full of aches and pains, then you will appreciate any mechanical aid that helps with the simplest tasks.
Use a shovel. A childs one from a bucket and spade for sand is is my limit. Very Happy
Use your foot to raise the wheel. Try that with arthritic joints in your feet. Very Happy
Apart from that some good suggestions for the fit and able posted. Thumbs Up
Post #286741 16th Oct 2014 1:35am
I think PSA had this with some of their vehicles. I'll have a dig around and see if I can find one.
Pro tip is when jacking up get the wheel just a mm off the ground. Worst case scenario is you have to jack it up a bit more Smile
With the ff using nuts not bolts at least half the job is done Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #286743 16th Oct 2014 1:42am
Robgosty
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
Only problem is they are in USA Sad
http://www.roverparts.com/Parts/WMAT
Post #286772 16th Oct 2014 8:40am
paulmoran2
ShadowBG Thumbs Up Thank you. That's the exact thing...and you even found an example on a FF...Full marks that man Bow down
Now I just need to find a uk distributor or just import a set or ask a local engineering Co to knock some up.. Just see how much easier it looked...If i cant get any, the shovel idea appeals too.
@craig...don't mind getting dirty, its just the shear weight I struggled with to get them aligned.
Post #286773 16th Oct 2014 8:50am
I think that's a really good idea. Thumbs Up
Might be worth considering a Group Buy and importing a quantity, I would certainly buy a set.
Post #286781 16th Oct 2014 9:33am
