![]() | Home > Maintenance & Mods (L322) > 2005 TD6 Alternator replacement |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1800 ![]() ![]() |
Hardest part is getting the viscous fan off. Fairly straight forward if you are handy with the spanners.
jinx1959 Member Since: 08 Aug 2014 Location: North Ayrshire Posts: 16 ![]() ![]() ![]() |
Many thanks. I thought there would be no way of getting it off without taking fan and coupling off. Looking forward to that.
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
There's nothing in the wiki for TD6 alternator replacement. Be good if you'd take some pictures then it can be added. |
If weather is ok tomorrow I will strip the old one off. I am expecting delivery of new one on Friday so it would be good to have it stripped down ready to go. There is a video on youtube that shows how to remove the viscous fan and cowling so I will have a look at that before I start.If I am successful I will take pics as I go along |
crispy2 Member Since: 18 Aug 2013 Location: Mandurah Posts: 102 ![]() ![]() ![]() |
One thing to be aware of is the main nut (36 mm I think) between fan hub and the thread that it attaches to is left hand threaded.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Why does every operation on the TD6 involve removing the |
Yes, good point there. It is a pain to have to remove the fan, but life wasn't meant to be too easy.
Do something simple.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7894 ![]() ![]() ![]() |
Should help;
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
I have removed the viscous fan (4.4 v |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6418 ![]() ![]() |
Vicious fan (intentional speling mistake) been off my TD6 too for 18 months, no problems, apart from taking up room in the garage. .
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8509 ![]() ![]() ![]() |
Have to agree, took mine off and replaced it with a twin electric setup from a Jaguar, but it's not really needed, the aircon fan comes on in stages if it gets hot...
Mine has never gone to full speed and I have tested high speed works as well but he'll even with the engine at revs you could easily hear it over the engine lol it Deffo pushes a LOT of air into the engine bay! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
I know that you can replace the serpentine belt with the fan on, so my question is WHY do you have to remove the fan to get the alternator off, I have never taken the fan off to replace the alternator on any other car I've worked on. Mind you I have had to remove the air box / filter, turbo pipes and air con compressor to get at the alternator on a landcruiser, |
