![]() | Home > Technical (L322) > How to fix One Touch window closure |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
When you remove your battery, or disconnect etc, you can find certain things have been wiped from the car.
gav Member Since: 03 Jan 2014 Location: Hertfordshire Posts: 37 ![]() ![]() ![]() |
awesome! I'm off to try this. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8536 ![]() ![]() ![]() |
Handy tip, works on most cars and also works on the sunroof... Pete
Didn't solve mine.... |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
Only works with the engine running.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Adam, its pretty much the same as doing a lock to lock with the steering when reconnecting the battery so the steering angle sensor knows its perimeters... It shows the window motor its perimeters too |
MachineHead Member Since: 20 Apr 2014 Location: The hoose Posts: 310 ![]() ![]() ![]() |
can you turn if off easy? I find opening window in rear for dogs a pita it either tries to keep opening or keep closing. It becomes a delicate game of how light and fast can you flick the switch |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
^the switch should have a 2 stage action, around half way pressed there is a stop, press it past this and it auto opens the rest of the way. There is nothing that can't be fixed with a hammer😜😜
The one touch function can be switched off via the CCF files too |
