![]() | Home > In Car Electronics (L322) > Rear dash camera fitment |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
After I fitted the front camera with great success ( http://www.fullfatrr.com/forum/topic23389.html )and inspired by cliffy's post (http://www.fullfatrr.com/forum/topic24647.html?highlight=rear+camera) I wanted to fit a rear back up camera but didn't want it just working when in reverse but when moving forward and wanted a camera that recorded, I found this little camera with the AV cable built in to the wiring loom, its the same size as the front 0801 model but with no screen on the camera and cheaper.
So as per my front camera I needed to find another ignition live in the front fuse box, there is NO ingnition live at the rear fuse box, its all positive live, but this was handy for the camera to have the memory stored. So wiring up the inside the A pillar again and under the head lining, removing door seals, grab handles and the 2 dog guard clips and feed through, missing the air bags, and down the D pillar to where the sat nav area in the rear near side. Using fuse 42 the vanity mirror to piggy off
No ignition live but useful for the camera memory, wire cable fed through the spare wheel well and fused.
Next was to make a bracket as fitting the camera to the tail gate was an issue ( see the end ![]() A piece of 2mm alli strip, shaped and bent to fit snugly
Next take the centre console off, the switch to fit. Watching the youtube video you don't need to take the hand brake handle off or remove the selector grip off either, why make work for yourself, you only need enough room to feed wires in so didn't see the point.
And look, my FF worth �2.55 more! previous owner lost it ![]()
Next was to find a good place for the switch, thinking where to fit, just under the dsp switch on the centre dash using a similar switch or in the coin tray infront of gear selector, or even near the high/low and HDC switches neither where ideal, as involving to take more to bits and the coin tray way would look wrong, so the switch went here.....
the simple wiring
And the finished camera
the camera is both NTCS and PALL but you need to change the setting on the head unit to NTCS for it to work correctly. As I didn't need the camera on for all reversing this set up is great for me and you can use it in forward motion for your passengers watching the idiot ( you know the type) behind you! Picture doesn't show up very well as it the grey day here and I only have a HTC phone camera.
What issue, well after I fitted the camera to the tail gate and shut it the camera recorded everything backwards, numbers where like looking in the mirror and sd card issues, so it went back and got another one! There was a fault with the camera first of ![]()
SD card was in the camera on both pictures ^ v
the screen was rolling up the every few seconds, card was already formatted and both head unit and camera on NTCS
Edited links for camera, av cable adaptor and wiring diagram If it dont work.......burn it! If the IId tool cant fix it.......burn the FF. If the FF cant be fixed......buy a Land Cruiser! If the LC cant be fixed..............................................BUY a horse !! Last edited by Welshdragon on 12th Sep 2014 12:01pm. Edited 2 times in total |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Nice job WD |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
nice idea on the 'clip' mount... ... - .- -.
Not wanting to start a new thread on cameras, today I have fitted a rear view camera to the horsebox trailer. So far it looks good on the screen in the RR.
Not bad for under �8 ![]() If the IId tool cant fix it.......burn the FF. If the FF cant be fixed......buy a Land Cruiser! If the LC cant be fixed..............................................BUY a horse !! |
i think ill get one of those, �8 for the camera and �5000 for the horse box |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
If you want to put an ignition live in the boot there should be one in the trailer connector.
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
@WD Thanks for sharing ... once I get through my list of preventative maintenance I plan on doing this |
Went out with my girl today, first time to use the trailer camera since fitted......I must say it works a treat in seeing how she's traveling in the box
And I saw a fellow ffrr forum user too...... you probably spotted me before I thought it was you mate ![]() ![]() ![]() If the IId tool cant fix it.......burn the FF. If the FF cant be fixed......buy a Land Cruiser! If the LC cant be fixed..............................................BUY a horse !! |
horsey TV |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
@WD stop horsing around!! |
dand Member Since: 03 Sep 2014 Location: Wokingham Posts: 50 ![]() ![]() ![]() |
I can't see that trailer being there furlong. |
Chasazim Member Since: 21 Jan 2015 Location: Perth Posts: 128 ![]() ![]() ![]() |
Hello, thanks for the good write-up, I have done the same and it works well. Here is a question, can you get the radio to work while the screen is showing the idiot behind? The co-pilot wants music while she reports on what is going on behind. |
Well I thought all was working well but that was parked in the garage |
