![]() | Home > Technical (L322) > Ultimate infotainment upgrade |
BBS SPY Member Since: 20 Apr 2009 Location: Limassol Posts: 101 ![]() ![]() ![]() |
Hiya all
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35647 ![]() ![]() |
are you the bloke from black box..you obviously got the 'know how' how to do this , good luck and we definitely need pictures of your progress.. |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
that is one major job, a complete loom, optic fibres, control boxes and brains.. plus all the touch screen,amps,nav unit ect,ect.. do you have a good sorce of parts. funny i do have a late ulf module V8 facelift Range Rover Autobiography 22" wheels.
Colin, I am most definitely interested in this. You recall we exchanged mails on retro-fitting the factory NAV to my 07 L322 HSE. Well, I'm still struggling to list all the part numbers, specifically loom numbers for it.
can he tell me how to run a venture cam on the ibus system, i would bow down |
doublejay Member Since: 08 Nov 2009 Posts: 131 ![]() |
has daveo met his match ????? |
I really do thank you all so very much for your many very kind comments of support and i am humbled by the comments of acknowledgement |
bbs spy, just been reading your posts on another forum re the 'hawkeye exchange' which i found very interesting....btw what unit of yours will clear faults and adjust drl's and tv in motion... |
I sure am please Colin. Also, I'm STILL trying to get a look at some looms for the part number tag so if you come across those as well during your upgrade process please. There's definitely no plugs & wiring for these in mine so it has to be some kind of overloom. I'm also guessing there are a few other bits I shall need but I did manage to get hold of this diagram from TOPIX. Not sure if it's the whole story though. Any of these other bits you might know of would also be appreciated. I'm due to ask Nick if he can help with part numbers as well.
1 - Roof pod (global positioning system (GPS) antenna) 2 - Microphone - Voice recognition 3 - Touch Screen Display (TSD) 4 - Integrated Head Unit (IHU) 5 - Instrument cluster 6 - Traffic Message Channel (TMC) tuner 7 - TMC antenna amplifier 8 - Navigation computer Anyway Sir, best of luck. If you need any help finding parts etc I'm due to visit a few of the well known breakers in the next few weeks. All the best Dom |
Hiya Scarey, Ah yea, the hawkeye exchange thread. |
hi BBS SPY, I support you in what you are doing, the ulf module is the blue tooth unit, i fitted the 13th genaration one to my car,rewired the 54pin plug and you have it all,blue tooth,voice controll on both phone and nav unit, i have the pre touch screen system in my car but i have a few goodys like, full venture cam system and 2010 5 camera system but these use the can bus so my car wont speak to them.. i did read an artical in land rover mag about a couple of landrover tech's driving back from france in there 04 range rover and they talked about the venture cam set up watching the trailer they were towing..
bbs spy......be handy to have someone on this forum with this extreme kind of knowledge...i appreciate what you say re flogging your wares and will have a very detailed look at you site.. |
Thanks guys
Of course i can. But you really have no need to Bow ![]() As you know ,the origional BMW I-bus system is not directly compatible with the Later Can Bus system introduced in 2006 MY (from 1st July 2005 actually) In these CAN models, the Instrument pack also has an I-Bus interface for things like the setas, steering wheel controls, rain sensor, clock and PDC etc. However as you should know, the later Infotainment and Venture cam stuff was introduced at the 05 MY. and i suspect that the article you mention might have referred to an 04 registered vehicle, but built after 1st July 04, thus really making it that all important 05 Spec. So the big question is, how did they do this in the 05 Year? The answer is indeed that little known nugget of info you seem to be missing and is also the Key to my entire project. They knocked up a small specialist gateway ECU to go between I-Bus and CAN, Part Number YWC500422 ![]() Here's the one i just bought for my project. http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...K:MEWAX:IT However, this gateway ECU does much more than translate I-Bus to CAN. It also, like its eventual Ipack replacement, holds the vehicles CCF (Car Configuration File) data and SOM (Security on MOST) data. It's CAN bus port is also connected to the Diagnostic socket, over which it is programmed, the Venture cam dock unit and the IHU (Intergrated Head Uni) which is also the gateway to the MOST Bus and infotainment system. I am not sure the Gateway module can even function without the IHU, but i will hopefully find out for you during bench testing ![]() |
hi bbs spy, i read your post with a big smile, i would like to push the speck of my car higher and hopefully you can help, i also have done the car pc in my car that runs great, the only thing that lets it down is the monitor as the res is not that great. the touch screens have far better res on them..any way as i said if you need any thing posted on at this end the pffer is there
