![]() | Home > Maintenance & Mods (L322) > Reservoir & Valve Block Removal |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6433
Ongoing efforts to foil "pressure static" fault - Welshdragon's replacement of the pressure switch didn't work, so I had a look at the valve block.
I forgot to mention, I also tested resistance on a few things:
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
Jo,
Thanks Haylands - another good tip to add to the list to try and solve this annoyance |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
wikified . |
| Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419
That's the wrong diagram for the pressure sensor, it shows the compressor temperature sensor and valves in the compressor. You want the next page of the manual |
Oh well, it lasted a day before it faulted again. Onto the next fix |
| paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422
Joe90...sorry to hijack, but you say that if the car is on axles stands and you deflate the susp airbags, the wheels will lift?...is that on all years as I thought that the system only allowed wheels to raise when under weight from gravity ( ie when car pushes them down)?
I only had axle stands under one side of the car, and with this side wheels up on 4" blocks, so the tilt as the other side went right down may have caused this effect. That said there was no weight on the axle stands when I started to deflate and the wheels were off the blocks when finished, so there must have been a bit of "Citroen" effect going on.
Got'it. Ta. Was hoping wheel swapping had got easier
Jo Did you check the reed valve... could be a free fix!! Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
| Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902
And after all that work too |
@ Welshdragon
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1027
when you remove the head off the wabco compressor, you should see the flat reed ( metal) valve shown below as you turn it over
