Home > Maintenance & Mods (L322) > Kick in the Nuts Right Enough Contra
Contraband wrote:
So, it takes a fully trained time served land rover technician 1.5 hours to find out the alternator is goosed? Rolling Eyes
Incidentally, what would they quote for diagnosing the following?
Low washer fluid
Flat tyre
Broken window
Crashed
Burnt
Post #274774 7th Aug 2014 9:30am
Ah well , car been uplifted out of Stealers , on route to indie ..... Whistle ====================================
Post #274807 7th Aug 2014 12:44pm
pld118
The end of a beautiful relationship....
Post #274816 7th Aug 2014 2:53pm
but will it come back to mick or will it go straight to WBAC... ... - .- -.
Post #274838 7th Aug 2014 6:00pm
Emperor Mong
As main dealers go, you have to doff your hat to Aston Martin Works Service. They charge like a wounded rhino, if you go a little off-piste (they are fine for servicing).
A friend sent his Aston Martin Vanquish there.
He had several thousand pounds of upgrades done to it by them.
The car was missing the umbrella to go in the boot (it had the straps to hold said umbrella, it was just missing the umbrella). He asked for a new one to be put in (i.e. open the boot, put the umbrella in the straps, close boot). On his bill, he noticed a charge for "fitting the new umbrella" - labour £80. He questioned it. They eventually did knock that off the bill.
I had something similar with them - they offered to fit a new stereo. I asked for a quote - £200 if I supplied the unit. I said OK (I could have had it fitted free at the local place but I didn't want some work experience teenager pulling apart my Aston). The final bill they gave me was for £2,000. I argued them back to £200.
Post #274839 7th Aug 2014 6:01pm
Mikey
It's around 2.5-3 hours, tops to replace. Done loads of them
A new Denso (OEM) unit can be had for £265.
Fully charge, or recondition the battery, and go from there Thumbs Up
Post #274846 7th Aug 2014 6:33pm
60 / 40 on that one stan Thumbs Up ====================================
Post #274851 7th Aug 2014 7:15pm
Car back all sorted , new alternator and new battery including labour £797.40p so that'll do me , just a PITA the stealer took £183 for lifting the bonnet ... Anyhow big question ,,,,,, do I sell or do I keep Rolling Eyes ====================================
Post #274972 8th Aug 2014 5:29pm
Keep.
Post #274979 8th Aug 2014 6:04pm
You've been after a change for quite a while I think.... So do it.. Previously..
Post #274983 8th Aug 2014 6:08pm
pld118
Better the devil you know for me... Buy some furry dice and if you can throw a 7, change it then! Thumbs Up
Post #274994 8th Aug 2014 7:35pm
