Home > Technical (L322) > How far can I drive with no coolant ?
Got a coolant leak - should I insist the RAC recover it or if they can find a local garage should I risk driving it ?
I was planning on telling them to recover it, but want to check that's reasonable ?
I guess I should tell them I'll only drive it if then take responsibility for any damage Very Happy
Just answered my own question I think.......
Post #242866 15th Feb 2014 7:17pm
Wouldnt drive it too far, if at all, wont take long to damage the engine with no coolant.
Not sure how long in the ff, but our old lc dropped its coolant when a bottom hose went, lasted about half a mile and the head warped, never the same again. Needs to go on a truck! There is nothing that can't be fixed with a hammer😜😜
Post #242869 15th Feb 2014 7:39pm
Rosco
agree , don't move it Thumbs Up
Post #242871 15th Feb 2014 7:56pm
fisha
When you say coolant leak, how much? Has is dumped everything or just lost a bit ?
If its everything, then don't drive it.
If its just a bit, and the leak is not fast, then topping up with water will get you somewhere. As long as water in it, then it'll stay cool. The % amount of anti-freeze to water is not as critical as having water. i.e. don't worry about diluting the coolant by simply adding water alone. V8 or else ...
Post #242875 15th Feb 2014 8:24pm
My "middle" hose popped off the rad (cloud of steam etc), managed to drive (very gently) a further three miles, temp gauge stayed at vertical throughout. But above advice is sage, don't if you can help it. .
Post #242878 15th Feb 2014 8:30pm
Careful just adding water in the alps.
As it Gets really cold overnight it may freeze, in uk would be fine, but could easily drop cold enough to freeze the water if it was dilute enough Big Cry There is nothing that can't be fixed with a hammer😜😜
Post #242882 15th Feb 2014 8:57pm
Ragerover
United Kingdom 2006 Range Rover Autobiography 4.2 SC V8 Zambezi Silver
Don't even think about it ...not worth the risk Growing old is compulsory Growing up is optional
Post #242920 16th Feb 2014 2:00am
Thumbs Up Thanks - that's what I figured - I'll need to drive it out of the underground car park, but no further
Post #242963 16th Feb 2014 3:18pm
