Home > Maintenance & Mods (L322) > Which Diagnostic tool?
87RJD
Hi all
I'm looking to upgrade from my Faultmate FCR, the main reason I'm unable to reset needs a service info on dash display with it.
So which one to buy, IDD seems popular, but at £448 quite expensive. Lynx looks good as well, and £288. Any advice on advantages/disadvantages will be appreciated, and recommended suppliers.
Post #236142 20th Jan 2014 8:33pm
verydisco
I tested several, the IID tool is by far the easiest one and the smallest by far.
The latest generation is even bluetooth compatible Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #236150 20th Jan 2014 9:23pm
steptoe
Re: Which Diagnostic tool?
87RJD wrote:
Hi all
You don't need a diagnostic tool to reset the service light. At least not on the earlier models.
Post #236253 21st Jan 2014 1:07pm
87RJD
Hi, you are correct, BMW based cars are straight forward, Jaguar engined not so simple, unless anyone knows different?
Neutral
Post #236318 21st Jan 2014 6:57pm
SteveMFr
Site Sponsor
Hi RJD,
No you are correct, you will need a diagnostic tool to reset the service interval indicator.
As far as which diagnostic tool to buy, the IIDTool can only be compared to the Hawkeye/Lynx in terms of cost. Functionality-wise it is miles beyond the other 2. The IIDTool BT with our new VIN lock policy is more or less equivalent to a Hawkeye or Lynx Pro at 1/3 the price - our 'standard' diagnostic functions are more or less equivalent to all Hawkeye / Lynx functions. (BTW, do some price checking. The price you stated is anything but competitive. Britpart dealers can all set their own prices, so there are differences).
At the end of the day, it all depends on what you want to do with the diagnostic tool. I wrote a bit about this a while back, HTH.
Steve
SteveMfr wrote:
Choosing a diagnostic system is not always easy. I've tried to keep this objective - if you want complete objectivity do not read the '*explanation...' at the end of the post Razz
HTH in deciding what is best for you.
There does not seem to be much clarity on the functions of a diagnostic system and what to expect when you use one. Here's a short explanation (EDIT: ok long...)
First, there are four basic types of functions that a diagnostic system can have:
- fault code reading and clearing
- live values and component manipulation (to check operation) or executing service routines (such as for the EPB)
- Editing the car's configuration files (CCF)
- Initializing, calibrating, or programing new components
Then you have to separate different types of faults or DTCs (Diagnostic trouble codes):
- generic OBD codes: these are all the emissions related codes that come from the drivetrain (motor and transmission). These are standardized across all manufacturers so that they can be read all over the world at emissions testing stations. There are OBD readers starting at £25 that do a fine job of reading these. Some even manage to clear fault codes.
- manufacturer specific codes: all the rest of the systems on the vehicle. In a Hyundai that is probably not too much, but in a modern LR it is quite a bit - and many items such as the EAS, ABS, DSC, etc. are vital for vehicle operation as well. These can only be read by manufacturer specific code readers.
Based on this you can separate the diagnostic systems into different categories:
- generic code readers: only emissions related OBD codes. Start at ~£25. Some of the more expensive ones may include live values (engine/trans only) and the non-generic ability to clear SRS faults (turn off airbag light) which makes them attractive for small, independent repair facilities.
- manufacturer specific fault code readers: can only read and clear faults. Shows no live values, allows no manual component activation/testing, no vehicle programming, etc. The only 'pure' fault code read/clear device for LR vehicles is the Blackbox FCR.
- manufacturer specific diagnostic systems more for personal than professional use: allow some or all of the functions of a full diagnostic system: live values, manual component activation/testing, vehicle programming, etc. Depending on the cost, these may or may not be locked to one vehicle VIN and have increasingly more functionality with increasing price (we went a slightly different direction to try to reverse this trend for the IIDTool - see below*). These start at the low end with the RoverAllComms (only early RR L322) and Hawkeye, and go through our IIDTool and the Blackbox Faultmate. The latter 2 are VIN locked.
- professional diagnostic systems: these include the OEM LR IDS/SDD, Autologic, Blackbox Faultmate, and IIDTool Pro (coming end of 1st quarter 2013)
Choosing the right system requires spending a bit of time looking at all of the relevant information. If you do not want to do any CCF editing and a a fair bit of basic maintenance on several LR's, the BBS FCR or Hawkeye/Lynx might be the way to go (but be aware that the functions offered are quite basic - for instance the Hawkey/Lynx can not do an EAS calibration if you replace a height sensor). If you want to do more but only on a few vehicles (say 1-3), you'll have to look into what the BBS Faultmate or IIDTool have to offer. If you have a club (or for an independent service facility) you can look into one of the professional systems such as the IIDTool Pro, FaultmateMSV, Autologic, or IDS.
*Explanation on the IIDTool pricing: We specifically looked to partner with a large retailer in order to be able to sell larger volumes and keep the price very competitive. In our case this worked out well with Britpart as our distribution partner. We also used the vehicle as an 'interface' to keep hardware costs low (thus Integrated Interface Diagnostic Tool). Essentially, the IIDTool provides similar functionality to diagnostic systems costing 3-4x as much.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #236330 21st Jan 2014 8:00pm
