![]() | Home > Maintenance & Mods (L322) > Range Rover L322 - Stuck in Extended or Off Road Height |
I just thought I would share a small problem I had with my Range yesterday. It may be one for the WIKI.
The fix is to remove this filter using a 13mm spanner (Its shaped into a nut head at the top) get back in the car and start up and then select normal suspension setting. The system will let out a gasp as the compressed air is released and the car will drop to normal. The code can now be cleared and all will be well. The car can be used without the filter (bit noisier) but this is probably not sensible in the long term. Ideally a replacement needs to be sourced but I think these are only available as part of a service kit. Another option is to drill a tiny hole through the cone filter through the middle to allow air to escape but very little chance of anything nasty getting in. The Cone filter can then be refitted and all is good. Tiny hole drilled through from thread end of cone:
I believe there is a service kit with a new filter cone (sintered brass filter), but I strongly recommend also replacing the dryer at the same time, as its desiccant is what causes the muffler to clog in the first place. ![]() I think these "9mm Thread Sintered Brass Pneumatic Filter Noise Silencer Muffler" will fit: http://www.sourcingmap.com/pcs-9mm-thread-...tAodnDIAsw http://www.amazon.co.uk/Thread-Sintered-Pn...B008ASX7P4 Last edited by Gazellio @ Prestige Cars on 16th Jan 2014 12:03pm. Edited 9 times in total |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Great little fix that Gaz, and easy enough for anyone to do.
Yes Adam really is a 15 minute fix that a Dealer would probably charge hours for (as they probably would not know what to do) and end up replacing all the height sensors first |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
its a known fault,
Yes Stan but that post is not exactly a WIKI fix is it.... |
Just need to know the thread size and one of these should work ok.
Yes I think the thread is 9mm I added this to the thread a little while back:
I have ordered from Amazon... |
Never noticed your Edit |
Yes my thoughts exactly even though the drilled one is working perfectly! |
Sorry yes this was 200MY Vogue SE Supercharged - I will add to post above |
jak480 Member Since: 06 Dec 2013 Location: Degernes Posts: 44 ![]() ![]() ![]() |
Hi
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
. . . I'm going to check mine now you've mentioned it, Gary.
Something to think about |
