Home > Maintenance & Mods (L322) > supercharger oil change
Page 1 of 3 123>
reading through this thread http://www.fullfatrr.com/forum/topic14188....oil+change
it suggests changing the oil in the supercharger with a kit supplied by these peeps http://www.ebay.co.uk/itm/160676739255?ssP...1438.l2649 .
so i was wondering if anyone has done this job and if so can they give us some tips or a 'how to'..
Post #232522 3rd Jan 2014 11:37am
davrr
United Kingdom 2007 Range Rover Vogue SE Supercharged Atacama Sand
Have recently purchased one of these kits, but not got round to carrying out the job yet.
Post #232559 3rd Jan 2014 1:44pm
Stan: I'm intrigued by your find, so ordered a kit.
My local specialist tells me supercharger access on the RR S/C is 'terrible' compared to the Jaguar installed unit, so I hope that doesn't mean the fill plug. I'm guessing this plug is at the top of the unit, though. Si. <This is my name.
Post #232829 4th Jan 2014 4:55pm
i've looked through the WM but cant seem to find where the fill hole is ...
Post #232838 4th Jan 2014 5:54pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
I have heard the L322 SC needs to be refilled with a syringe due to poor access - there was a thread about 8 months ago on here where somebody did it.
Post #232886 4th Jan 2014 9:25pm
ebajema
My mechanics couldn't find the fill plug and the workshop manual I have doesn't show it either so I need to look myself when I have the car back. It doesn't seem to be in the Jag location. MY 2010 5.0 SC Galway green and sand interior!!
Post #232889 4th Jan 2014 9:35pm
HUGI
Switzerland 2006 Range Rover Vogue Supercharged Java Black
anyone did this? any hints?
I am planing to do this next weekend with a friend who is a mechanic.
Post #235177 15th Jan 2014 10:42pm
verydisco
looking forward to read more l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #235552 17th Jan 2014 4:40pm
HUGI
Did it today.
detailed How to with Pics will be ready in some hours.
Post #249872 22nd Mar 2014 6:42pm
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Thanks Hugi - was just coming on to research Supercharger oil changes as well Thumbs Up
Easy job?? 4.2 Supercharged Vogue SE
Post #249875 22nd Mar 2014 6:52pm
HUGI
so lets start with the job:
First imagine a SC without this silly plastic cover. If you like I can take pics how to remove the cover too.
here it is:
now you see a black plastic part with the weird shape connected to the Airfilter: Air Intake Duct Boot (PHD500075)
this you can remove very easily.
It will look like that:
This screw you need to remove to suck out the oil.
and on the technical diagram:
It needs a specific allen key. (We didnt have so we had to make one to fit) Size: (3/16)
Removing the nut there seems complicated with the throttle body intake in place.
So we decided to remove the throttle body intake (part no: LR005192)
Here you can see which Parts you need to remove. It is Part 1 and 4.
First you have to undo in the back and lift the throttle body intake and pull it towards you.
Then it is pretty easy to undo the nut and take out the old oil and refill with new one. Probably the nut is stuck and you need to spray it with some WD40. I would advise you to put a rag down there so if the nut or the allen key falls you can grab it easily.
I used the syringe which was included in the Kit I bought from EBAY. I got 170ml out of the Supercharger. The Oil capacity is 215ml. To get out as much as possible lift the car in the back a bit so the oil is flowing to the front of the Supercharger.
Then refill the Supercharger with the same quantitiy of oil until it overflows (second reason to put a rug or a piece of cotton there) Just tight the nut again and you are done.
Please be aware! You need special Oil. I read some topics somewhere else about people using normal engine oil?!! Censored
Hope you understand my approach even if English is not my first language and I am not very familiar with technical terms.
Post #249933 22nd Mar 2014 11:34pm
Monty1
England 2005 Range Rover Supercharged 4.2 SC V8 Rimini Red
great write up
Post #249964 23rd Mar 2014 7:00am
Chauch
Thanks Hugi, that is superb Thumbs Up
Looks within my limit of ability as well. How much oil did it take?
Would appreciate more details of the specific Allen key... 4.2 Supercharged Vogue SE
Post #249969 23rd Mar 2014 8:45am
Av_dave
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Perfect how to guide I must get round to doing mine. The difference between theory and reality is that in theory it will work.
Post #249970 23rd Mar 2014 8:46am
Yes, a great write up sir Thumbs Up
Post #249972 23rd Mar 2014 8:49am
Page 1 of 3 123>
