![]() | Home > Technical (L322) > wing mirrors gone mad |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35546 ![]() ![]() |
a quick double press of the door mirror fold button normally works [might need to be done a few times ] or a battery disconnection.. |
NormanP Member Since: 15 Mar 2013 Location: Oxford Posts: 136 ![]() ![]() ![]() |
As Stan says, might need to do the button press a few times. More here:
redshovel Member Since: 11 Jun 2010 Location: Belfast Posts: 244 ![]() ![]() ![]() |
This happened to my ff once. Only solution was a battery disconnect for 10 mins. Went back to normal and never happened since! |
MikeG Member Since: 14 Apr 2013 Location: Netherlands Posts: 182 ![]() ![]() ![]() |
Andy, I had this a couple of months ago and the double press of the mirror button did the trick... Although I must say don't give up... I recall I had to do this at least a dozen times back to back after which the system reset itself again and all has been fine ever since. Mike.
