![]() | Home > Maintenance & Mods (L322) > wheel arch rubber seal |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35598 ![]() ![]() |
found this,
I've used the door edge protector shown below on the wheel arch return flange.
Having seen this post via another recent similar post, on the basis that it's tried and long term tested by NDF (and has good logic in that there is no metal in it) I've just ordered 2 x 2M strips of these for £5.98 delivered.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3779 ![]() ![]() |
Me too! Going to smother it with any old grease or waxoyl lieing around in the workshop |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7894 ![]() ![]() ![]() |
Vaseline is also suitable I believe, and available from most supermarkets. 2011 Range Rover Vogue SE 4.4 TDV8
@ pld 118
Thanks NDF, much appreciated |
@ndf - would your grease 'paint' do the job on the rear tow eye too (showing minor signs of oxidised discolouration) or is there an alternate rattle can solution for the rear tow eye?
Today bought the Comma grease (£6.99 Halfords) as advised by ndf and set about fitting the rear arch strips recommended by ndf too.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6418 ![]() ![]() |
flange - now there is a good word - flange |
@pld118.
@Joe90 - definition = "A flange is an external or internal ridge, or rim (lip)... " ... and we'll park it there methinks |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
