![]() | Home > Technical (L322) > Overheating? Coolant Loss & PTFE (2 recent Rads fitted) |
The car hasn't been used much in the past week or so.
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
The black crosshead cap is a bleed screw for the cooling system. It allows the system to be "burped" when refilling and, if not tightened afterwards, will let coolant leak out when the engine gets up to temperature.
Thanks very much Budgie. Really helpful and much appreciated |
Thanks NMJ. |
You need to use exact same as what is already in the coolant tank! |
Thanks Gary/ thought that... Will ask dealer when they open. |
Just been to LR main dealer to collect 1 litre of the same coolant they use. Yet again, they were very helpful. Didn't drive the SC as the coolant level has dropped to about 1" below the minimum Range Fill marker. Will use a 50/50 mix with water, tighten the bleed screw and touch wood, all will be well.
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Are you sure it was overheating ? Something major wrong if its overheating when the level is just below the minimum level, that coolant system has massive over capacity for our conditions........
When making my OP I had noticed the temp gauge had visibly moved from the 10 to the 12 o'clock position within a couple of minutes of driving; and there was that smouldering radiator stench when I stuck my nose up to the front grille.
It`ll bleed out OK, mistake u made was topping the tank up with the bleed screw open, you should have left it closed..........they are a |
Having ran the car to operating temp, then taking it for a moderate drive with no obvious problems and the Temp gauge remaining at the 12 o'clock position, parked the car overnight and no coolant loss/ levels same as when I topped up yesterday evening.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8742 ![]() ![]() ![]() |
Sounds good.
For info..
Thanks NMJ/All... It appears one could easily do the wrong thing re coolant and yet it should be straightforward.
