![]() | Home > Technical (L405) > Knocking noise |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35602 ![]() ![]() |
take a video of it when it happens and that will hopefully help the dealer find the problem..
Gremlin Member Since: 24 Sep 2008 Location: Kent Posts: 33 ![]() ![]() ![]() |
It is the new type terrain response 2. So my dealer told me |
Sb Member Since: 18 Sep 2013 Location: Leeds Posts: 33 ![]() ![]() ![]() |
It did it as we drove it away from showroom. They've accepted there is something wrong just don't know what to do!!!
Nothing they can do So they say. |
None of the demonstrators that I drove did it, don't think I'll be accepting that response. |
Back it |
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 ![]() ![]() ![]() |
Suggest that the dealer looks into active roll bar issues and engine mounts. Does the knock only occur when in a straight line? 2019 D5 HSE Lux SDV6 Indus
My thought was active roll system too. Does it in straight line and when cornering, its more prominent on bumpy roads or when there is a sudden dip.Dealer says they have found the problem and should get car back tomorrow. However, we will see.
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 ![]() ![]() |
Hope you get it fixed soon, I'd be wanting a sweetener when its finally fixed. May be a free service Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
Guess what? It was the active anti roll bar.
Same old story then. Oddly mine had a new ARB but that was the only one too! Glad they have fixed it, enjoy. 2019 D5 HSE Lux SDV6 Indus
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 ![]() ![]() ![]() |
recall on valve that causes air to get into the ARC Far to many gone... |
RR4ever Member Since: 14 Aug 2013 Location: Hertfordshire Posts: 21 ![]() ![]() ![]() |
Interesting thread. My new SDV8 ATB is going in next Friday for exactly the same grunt from front nearside. Luckily I'll now be able to tell them the solution! I did the same last week when I had the vibration from under the bonnet at 1300 rpm. Someone on the forum pointed out there was a JLR Bulletin on the issue "SSM63877 L405 V8 Transmission heat shield vibration 1400-1600 rpm" . That's the value of the forum! MY15.5 SDV8 4.4 A/B FFRR Mariana/Ivory
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 ![]() ![]() |
How is it acceptable for a car of this expense to have problems already!
