![]() | Home > Technical (L322) > transmission fault only limited gears available |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
right now - only had the RR back on the road for a week or so and keep getting the message in title
Could be a transmission overheat. Have you checked the Transmission Oil Cooler as this may be blocked especially if the radiator is sludged up. You may want to take the external Gearbox temperature next time. |
it only happens first time I start her up - cold engine after standing for a few hours
anyone?? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
not every knowledgeable member is on the forum every day , some only come on at the weekends or evenings ...
Cheers Stan - it is one of my faults - |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
To be honest, compared with the 5-speed ZF & GM units, there haven’t been a lot of issues reported with the 6-speed transmissions so there isn’t a lot of experience to tap into at the moment. I guess there’s a couple of reasons for this :
Cheers Phil
I don't want to discourage you but have a look at my posts regarding this gearbox. RRPhil has been great helping me to find the solution (waiting for a full set of coils now).
hi Ebajema
Good to hear the gear changes are fine. It could be something related to sitting still. One thing that is an issue sometimes is the gear linkage. If you get a chance, liberally spray the linkage underneath the car with WD40 and then cover it in simple white grease or something like Shell Rhodina II (specially developed for open gears offshore, so really good in place like the UK, NL etc.) MY 2010 5.0 SC Galway green and sand interior!!
Hopefully it will turn out to be caused just by low battery voltage, if the car hasn't been used for a while. Phil |
Found out what the issue was
Glad it was a simple fix |
