![]() | Home > Off Topic - Other Cars > Led running lights |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Vogue MY 2010 is the same - they are side lights and come on only with the switch. New model has them as daylight running lights.
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
On a 2010MY L322 onwards they can be switched on as DRL's with a faultmate |
Are you sure the Faultmate switches the LED's on as DRL's as the IID tool switches on the main beam at 40% strength or the headlamps only... No option for LED's |
Certainly does on mine |
Interesting... Thank you Andy |
As above, though you can turn on the the Scandinavian or Canadian DRL option as well with the Faultmate |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 ![]() ![]() ![]() |
Well according to that link the disco forum say they work in place of side lights although mine seems to have side lights and not drls...most cars have options to turn these on and off via settings I thought. 2009 Vogue TDV8 Nara Bronze
gvw Member Since: 30 Apr 2012 Location: South Yorkshire Posts: 10 ![]() |
Are you sure the LEDs are physically there as some of the lower models do not have them and have the standard sidelight |
Not sure they are there but the headlights have the pattern. So maybe this is a con! 2009 Vogue TDV8 Nara Bronze
All Disco 4 headlamps look the same but only top model cars have the LED's... Does your car have side light bulbs? If so the LED's are dummys. If you turn on your side lights and the LED's come on then "voila" |
RangeK1D Member Since: 21 May 2013 Location: Calgary, Alberta Posts: 166 ![]() ![]() ![]() |
Hey Ajay, which faultmate model are you using? I went on to the BlackBox solutions website but there are a bazillion products. Zambezi Silver Range Rover (2010 Autobiography Facelift)
Faultmate MSV-2 Extreme with SM136 RR 2010+ Multi-Vehicle Licence |
Lad Member Since: 12 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
The iid tool can switch on the led lights to come on ON their own when the ignition is switched on. |
