![]() | Home > Maintenance & Mods (L322) > 2002-2005 ZF5HP24 Gearbox Fluid Cooler and Component Change |
Excellent stuff as always Saint V8 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
in the wiki.. |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
Good write up |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
The cooler is coolant fed, hence the coolant thermostat. |
Gotcha it clicked as soon as I clicked post so I revised my post |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
Great work but if you read previous threads you would have known to check the main radiator which supplies the cooler.If you still have the old cooler you can put a hosepipe on it to see how it passes water ,mine was partially blocked and it sprayed back in my face and it had its radiator changed just a few years ago[date on side]When done if you feel each oil pipe in and out you should feel a noticeable difference.If possible get it checked by diagnostics which will show actual temperatures and temps it switches at.You cannot assume it is 100% sorted unless you know the radiator is ok .Good luck ! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8540 ![]() ![]() ![]() |
Saint V8 did this three years ago.... bit late for tips..... |
Ghostx666 Member Since: 07 Mar 2020 Location: West Midlands Posts: 11 ![]() ![]() ![]() |
Hate to revive on old thread but I didnt want to start a new one.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1559 ![]() ![]() |
Saint hasn't been here for 6 years - I guess the photos won't be recovered. Ron B. VK2OTC
Maybe PYX000070 - (WASHER - SEALING) ? Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
Yes, if we’re talking about these seals, the part number is PYX000070 – but they aren’t O-rings
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 986 ![]() ![]() |
You can find ant/saint on the landyzone |
