![]() | Home > Technical (L322) > Could this just be battery failure? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
I had some form of electrical failure on the way home from work yesterday in my 2003 V8 L322. Just driving along at around 50mph when I felt a small jolt (presumably the transmission selecting 4th gear for limp-home) followed by no response to the throttle pedal (engine was ticking over erratically, hunting up & down while I’m still coasting along at 40mph or so). I pulled over to the side of the road, turned the engine off, and when I tried to restart it I just got engine failsafe, transmission failsafe, HDC & air suspension faults all coming up on the message centre one after the other – oh, and the coolant gauge just went immediately to maximum. No response whatsoever when I tried to turn the starter.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35604 ![]() ![]() |
from reading many posts here it seems that the fullfat is prone to the 'cascade' ecu failure where one ecu doesn't get enough power then that results in the next one failing and so on...
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
When the engine is running you should in theory be able to disconnect the battery from the circuit and the alternator should keep everything going. The only way I can see your battery causing any fault when you are actually driving is if a cell went faulty and was pulling the voltage down from the alternator. I would be getting the battery tested first. |
Thank you all for your advice.
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 869 ![]() ![]() ![]() |
Is the ebox the one under the bonnet with all the torx screws in? Glad it was a simple fix for you, I'd have NEVER found that! My Previous RR's!
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8742 ![]() ![]() ![]() |
Good fix phil, lets hope its a permanent one and the blown fuse wasnt a symptom of something more serious. There is nothing that can't be fixed with a hammer😜😜
It turns out that not only does Fuse 1 in the E-box power the engine and transmission ECUs
Wauw Phil that is an interesting failure and you did well finding it so quickly. Glad to hear that you will soon be mobile again (you can probably drive like this anyway ??) also a good one for the Wiki (Stan, please ??) in case someone else gets this in the future. MY 2010 5.0 SC Galway green and sand interior!!
glad its sorted Phil.
Heated Thermostat Connector Failure: could generate multiple seemingly unrelated electrical faults ??? MY 2010 5.0 SC Galway green and sand interior!!
To be honest Eugene I was being guided to what to look for by a bloke on another forum (but I wasn’t going to mention that!)
I think that’s likely to be correct. Before I replace the connector I might just snip the old one off (to ensure that it isn’t shorting) and try driving around for a while. Presumably the engine light will come on, as it’s emissions related, but I could use the Faultmate to monitor the coolant temperature and maybe do a before and after comparison with and without the heated thermostat on the same journey. Phil |
This has been one of my gripes with all auto manufacturers (at least the ones who's cars I've worked on): the connectors are almost never available individually. AMP, one of the largest OEM connector suppliers has assortments available - but these generally start in the high 3 figure to low 4 figure range and even very large service shops can hardly justify a purchase such as this.
Maybe find a local breaker and spend 30-40mins wire a pair of wire cutters cutting off loads of connectors before a vehicle is crushed?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
He’s a technician at a Land Rover dealership in the US and I got the impression that he’s seen the (or a similar) problem before….. I’m assuming that if I run for a while without the heated thermostat connected up (just as an experiment) that the engine coolant will operate at maximum temperature i.e. the engine ECU normally intervenes to lower the coolant temperature, by powering the thermostat heater, when higher engine performance/load is required. In the Manual it states that, in the event of the heated thermostat failing, the engine controller will “ensure the safe operation of the engine” so I’ll be interested to see what it does. Phil
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
