![]() | Home > In Car Electronics (L322) > Digital TV Upgrade |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
Hi Steve, I've tried the link you provided again and saved the pdf file, but can't spot any difference from the original one? Ta. |
doublejay Member Since: 08 Nov 2009 Posts: 131 ![]() |
....my dealer won't confirm availability so I'm still watching this one with interest ! |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 ![]() ![]() ![]() |
Sorry about that here is a new link to the updated file
Cheers Steve, got the new pdf.
Hi Folks, not good news |
Only think that was right is that they are currently charging £75/hr incl vat for labour which seems pretty good.
jayzee Member Since: 14 Oct 2009 Location: UK Posts: 342 ![]() ![]() |
Give it time... they are bound to come down in price. I'm in no rush, and can live without TV until prices for the upgrade become more sensible.
We live in hope. I've now actually thought of another method which uses the £50 unit I mentioned earlier, but involves feeding it into a short range UHF modulator so I can transmit the signal from the digibox as a UHF signal within the car and pick it up on the TV the same way as I did analogue stations, this way , I could have TV in the front and back ( as, if I'm not mistaken, the 'AUX' connectors in the back of the armrest only feed the rear 2 screens, whereas my method would feed all 3). |
wiggs Member Since: 29 May 2010 Location: Manchester Posts: 182 ![]() |
Hi
I must say that that sounds very interesting. So it is just unplug the old tuner from the boot and plug in your D4 box? how do you access the epg? How much would I be looking at to get one with a new bracket?
The EPG is automatic ..just comes on when you select the channel ..although there maybe another menu i have not tryed .
Only 90 mins up the road Wiggs - I'm up for it. Discount for being guinnea pig ??? |
dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477 ![]() ![]() |
Also interested Wiggs - I'm down in Burnley next weekend so could drop down to you if you're about... |
