Home > Maintenance & Mods (L322) > flip keys (new order started)
This topic is locked: you cannot edit posts or make replies.  Down to end
Page 8 of 11 <123 ... 78 91011>
PipHudson
Paid Smile
Post #195689 23rd Jun 2013 7:00am
daveo
ZETJESTER, 2 ORIGINAL STYLE KEYS..paid
CRAIG 1 , 2 ORIGINAL STYLE KEYS ...paid
TSADPT, 1 NEW STYLE KEY ..............paid
MAGICBOB, 2 NEW STYLE KEYS.........paid
CHARLIE, 2 NEW STYLE KEYS............paid
PAULB, 1 NEW STYLE KEY ................paid
B9ER, 1 ORIGINAL STYLE KEYS ........paid
HAVANK, 1 NEW STYLE KEY...... ........paid
JCW, 2 ORIGINAL KEYS...................paid
DALZIEL, I ORIGINAL KEY
ANDY180. 1 NEW STYLE KEY.............paid
MPH28MPH, 1 NEW STYLE KEY..........paid
PIPHUDSON, 1 NEW STYLE KEY.........paid
two forum members still to pay
DOCJONES, 1 NEW STYLE KEYS
RICH89, 1 NEW STYLE KEY
the keys are on there way and should not be long now, Thumbs Up V8 facelift Range Rover Autobiography 22" wheels.
Post #195708 23rd Jun 2013 10:03am
daveo
DALZIEL, I ORIGINAL KEY ...............paid
DOCJONES, 1 NEW STYLE KEYS ........paid
one forum members still to pay
the keys are on there way and should not be long now, V8 facelift Range Rover Autobiography 22" wheels.
Post #196264 26th Jun 2013 6:09pm
daveo
ok, keys have turne up, all good, now they will be sent out standard post that would be included in the price unless you are out side the uk..i think have most addresse.
RICH89, 1 NEW STYLE KEY V8 facelift Range Rover Autobiography 22" wheels.
Post #197159 1st Jul 2013 11:29pm
Mph28mph
United Kingdom 2002 Range Rover Vogue 4.4 V8 Giverny Green
Great news that was quick.
Post #197160 1st Jul 2013 11:34pm
magicbob
2003 Range Rover SE Td6 Epsom Green
Standard post????? F Censored K.........that means here in Aussie, some bloody rag-head in his Mitsubishi Express van will 1...lose it, 2.....steal it, or 3.... not be able to read the address,(because it is in engligh) and send it to Pakistan, or some other f Censored ing god-forsaken dump!!! Big Cry Big Cry
Bob Laughing
Post #197183 2nd Jul 2013 9:29am
andy180
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Good news! Only a few more days until I can get rid of the old Fashioned BMW key!! Now: BMW 640d M Sport, Alpine White
Gone: Range Rover 4.4 V8 Vogue, Zambezi Silver, Charcoal Oxford Leather
Also: Mk1 Audi TT 1.8T Quattro, Brilliant Black
[URL=]
[/URL]
Post #197216 2nd Jul 2013 12:33pm
daveo
Bob Laughing
as in the first post.... Shocked unless you are out the uk....i will send it how ever you want.. let meget it wrapped and will come back with some prices for you... Thumbs Up V8 facelift Range Rover Autobiography 22" wheels.
Post #197281 2nd Jul 2013 5:43pm
daveo
PLEASE READ Shocked Shocked Shocked
OK the keys will start going out, as stated it will be standard post, if you want anything quicker than you will have to pay the difference. For those of you abroad I will check and get back with some prices.
WARNING, when you start your car with the key make sure the transponder is with the key, don’t be tempted to just test it with the chip next to the key, as when the car rolls the security code if the chip is not in distance it will not be updated with the new code, this happens each time you start the car, do not introduce both chips to the car as this can also cause problems and lock the EWS and then your car will not start even with the original key.
Step 1...first thing is you need to make sure you can sync the key,
http://s266.photobucket.com/user/daveo1000...2544040538
procedure; all remote handsets for use with the vehicle must be initialised.
Initialisation Procedure
1 Ensure the vehicle is unlocked and the driver and front passenger doors are closed.
2 Install a key/remote handset in the ignition switch, and then turn the ignition switch to position me and back to position
0 in less than 5 seconds to put the BCU into the initialisation mode. Continue the procedure within 30 seconds
of turning the ignition switch to position 0.
3 Remove the key/remote handset from the ignition switch.
4 Press and hold the unlock button for a maximum of 15 seconds. During this time, momentarily press the lock
button three times within 10 seconds.
5 Release both buttons.
6 Successful initialisation is indicated by the BCU locking then unlocking the vehicle. If this does not occur, repeat
step 4.
7 Repeat steps 4 and 5 with all other remote handsets belonging to the vehicle (4 maximum). Begin the
initialisation of each remote handset within 30 seconds of completing the previous initialisation, or the BCU will
drop out of the initialisation mode and the complete procedure will have to be started again. If you cut the blade or glue it together before checking this and there is a problem with the board they will not cover it,
Step 2 ...spare blades at the moment are like hens teeth so make sure it is done properly, after the blade is cut check it in the door to see if it unlocks, if all is good and the sync is done then put your transponder chip in the key, next pop it in the ignition and start the car, let it run for a while then turn off..Job done, run around for a few days with a cable tie around it until you are sure all is ok.
Step 3... When gluing the shell together do not over glue as if it goes on the board and there is a problem again they will not cover it.
The new style keys come apart very easy and with a thin flat blunt point you can flip the back off,
this will expose the board that comes out and then you can remove the silicon plug and insert your chip,
replace the plug. Refit the board and clip the back on...Job done.
The chrome side covers do clip off for those that may want to colour code the key.
Ok, on the original land rover flip you will need to sync the key, you don’t have the flashing light to tell you whats going on so listen out for the doors lock and then unlock,
These keys are new and still tight; I like to double wind the spring to give that bit more of a flick.
Then you take the key apart it will spring all over the place, don’t worry...
You should have these parts...
When you have the cover in two remove the circuit board
Now remove the rubber base cover,
this is where your chip will go, a spot of glue will hold it in place as in the picture, replace the rubber base and then the circuit board.
On the top cover you will find the key holder may be a bit tight,
this will loosen up after a while but if you want you can give a little sand and then a small bit of Vaseline and it will flick a lot more smoothly.
please remember, sync the key first, if you come back to me saying you cant sync it but have had the blade cut i can not return it...dont glue it together until you have used it and sure theres no problems,
i have had very little problems with the keys from this supplier, i have been through the keys and they all enter the sync mode so if you cant get it to sync just take a breather,relax and then give it another go...
:thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  V8 facelift Range Rover Autobiography 22" wheels.
Post #197476 4th Jul 2013 12:37am
B9er
Northern Ireland 2010 Range Rover Autobiography 5.0 SC V8 Java Black
Excellent, thank you Thumbs Up Should've been old enough to know better...doh!
Current 2010 5.0 SC Autobiography
Previous 2006 TD6 Vogue SE
Previous 1998 P38 4.6 Vogue Autobiography 50 (No 10)
Post #197488 4th Jul 2013 7:35am
daveo
Hi, sorry for the delay...all keys have been tested and are ready to go out, please could you drop me a pm with your postal address,as i am having trouble getting into paypal to confirm addresses.
the transponder chip is preglued in, if you would like me to remove it as it can be tricky, not a screw driver job as you will damage the case.. let me know and i will remove it for you...a few drops of de-onder and a pic gets them out.
Dave V8 facelift Range Rover Autobiography 22" wheels.
Post #197906 7th Jul 2013 7:12pm
zetjester
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
Cheers Dave, keys arrived and all's good Very Happy
Thanks again your a diamond Bow down Bow down Bow down
Jez
Post #198184 9th Jul 2013 3:53pm
PipHudson
Received today Thumbs Up going to have a crack at it now.
Will update if i'm lost
Post #198192 9th Jul 2013 5:30pm
PipHudson
All synced up, Now locks and unlocks doors. just need to get the key cut and swap over the transponder Thumbs Up
Good quality product. Really happy cheers! Very Happy Very Happy Very Happy
Post #198197 9th Jul 2013 6:00pm
tsadpt
Thanks Dave, you are a star! Transponder swapped, synced, and going to the locksmith tomorrow! Can't wait!
Post #198201 9th Jul 2013 7:21pm
This topic is locked: you cannot edit posts or make replies.  Back to top
