Home > Technical (L322) > Dunlop Airspring + strut defect...
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Hallo gentlemen, big problem: my 11 month old struts + airsprings are defect at their upper ball bearing, they make loud noises, when I use the steering at parking. Bought them at island4x4, on 28 of may 2012, good + fair company I believe? There is still one month warranty on them, so I order the DELPHI airsprings, only 20 GBP more p.p., had one of you still or in former times this problem? The noise is like a knock-knock of a defect ball joint front lower.
Best regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #188479 15th May 2013 5:12pm
le25dse
Norway 2014 Range Rover Vogue TDV6 Loire Blue
Hi Uli,
I've had mine for a little more than a year and they are still fine. I have replaced all bushings in the front suspension so I would have noticed if there was some strange sounds. ----------
2014 tdv6 (ex. 2004 td6, 1997 2.5 dse)
Post #188772 16th May 2013 9:41pm
ebajema
I have Delphi's which are the only ones for the SC and they are fine. Sounds like bad luck that yours failed, should not happen but apparently quality control had an off-day. MY 2010 5.0 SC Galway green and sand interior!!
Post #188775 16th May 2013 9:52pm
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
I replaced mine with dunlops from the same shop and I am having clunks at the moment but thought it could be down to drop links or some such thing. Only noise when going over holes in the road, and not when turning. When I received dunlops , they seemed a solid quality item. MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #188820 17th May 2013 6:57am
Meerbusch
the noise first seems to come from the lower part of the front suspension, but when I build the struts out, there is a very big "worn out joint top" (my englisch is not perfect). The man at island4x4 said, that I have to make pictures of the DUNLOP sign, and they don´t need the old struts back, there must be a serie of reclamations..., will see, an inform you all. Best regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #188844 17th May 2013 9:08am
Meerbusch
So, problem solved, the correct and fair company ISLAND4x4 sended me money back for the old DUNLOP struts, and they don´t want them back, I will give them in the mood-basket..., but the company DUNLOP in GB itself is very arrogant and unpolite, after three mails no answer, and after next mail they didn´t believe me, and they said, that there was no reclamation ever... (here in germany, 5 guys have the same problem like mine after only 4 month!!!!) So conclusion: BIG WARNING FOR DUNLOP struts!!! Rgs, Uli (The Delphi are much better, drive like new without any noise) L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #192332 6th Jun 2013 1:25pm
ebajema
Hi Uli,
Sorry to hear Dunlop didn't come to the party, very disappointed in them for that. Glad that the Delphis are doing fine, hope they last till the car goes to the great big yonder, i.e. with the Ludolfs Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #192357 6th Jun 2013 3:20pm
ahebron
New Zealand
Great! Crying or Very sad
I just bought and fitted a front pair for my TD6.
We shall see what happens.
Adrian VW Amarok 2014 Highline auto
Post #192486 7th Jun 2013 8:48am
Is the top mount not a separate piece? Dont know, just wondering... There is nothing that can't be fixed with a hammer😜😜
Post #192493 7th Jun 2013 9:19am
Meerbusch
@northernmonkeyjones, no it is one unit, not to open, because of the pipe from the suspension. Rgs, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #192539 7th Jun 2013 1:00pm
