![]() | Home > Maintenance & Mods (L322) > Just to be sure. Steering clunk. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6418 ![]() ![]() |
Re your comments on the ARB links, I noticed this too when removing/replacing them. One side (can't remember which now, I think RHS) required significant effort on the ARB to remove/fit the droplink, whilst the other side was easy peasy. .
Tayas Member Since: 29 Apr 2013 Location: United Kingdom Posts: 74 ![]() ![]() |
That sound just like what mine is doing. Can you be more specific as to which bolt? 2006 FFRR 4.2 Supercharged Vogue SE 2007 Honda S2000 2008 Aprilia Tuono Factory |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Thanks. I'll take a look once I'm back from Poland.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8744 ![]() ![]() ![]() |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
Disconnect the steering rack track rod ends from the hub but leave them on the rack grab hold of the bit behind track rid end and push / pull if the steering joint moves in / out its the inner track rod ends that are bolted to the rack under the big boot that are shot i had to replace both mine
Well, I just got back from the specialist and it needs a new steering rack. Great. £2.5k that's going to be.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35606 ![]() ![]() |
i'd be tempted to get a second opinion , just in case its not the rack.. ... - .- -.
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
If you do need a new steering rack then there are a few second hand on Ebay starting at £250.
Are all the racks on the FFRR the same regardless of model year? I thought some had variable ratio steering and some didn't.
Did you try a spanner on yir nuts?! Main dealer diagnosed my steering rack was away... Nothing wrong with it. Previously..
I did. They didn't budge.
http://www.ebay.co.uk/itm/Range-Rover-L322...3cd1b69b00 Previously..
But is that the same rack as on a 2006 SC? I can't seem to find anything definitive. 2006 FFRR 4.2 Supercharged Vogue SE
