Home > Maintenance & Mods (L322) > [SOLVED] Front Brake Disc Retaining Nut Seized !!
Damn, it has only been in there @ 18months and I copper-eased it on the way in. (Perhpas it explains why they were not fitted to the car when I bought it, but I didn't like the idea of the discs simply "floating", even though held in place by the pads and wheelnuts/wheel.
On attempting to remove, allen key just burred the edges. Hammered next size up into the hole, but that just span too.
Plan is to use a small cold chisel to create a notch, then use an impact driver on it. May apply low level heat from paint stripper gun too.
Any other brute force suggestions welcome Thumbs Up .
Post #184770 25th Apr 2013 9:15pm
A small pin type chisel to get it moving Thumbs Up
Post #184775 25th Apr 2013 9:35pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Blow torch to crack it.
Post #184785 25th Apr 2013 10:12pm
PaulB
Post #184786 25th Apr 2013 10:12pm
Don't have super heat e.g. blow torch, so will report back on small chisel approach Thumbs Up .
Post #184793 25th Apr 2013 11:16pm
Thumbs Up Thumbs Up Thumbs Up
Post #184796 25th Apr 2013 11:21pm
Big drill bit to get head off.
Once disc is off saw a nice DEEP slot in it and use a socket set with flat blade on the end to ease it out.
A light tap on the top of it if its still sticking can help release it.
To be honest I don't bother with coper slip anymore and stick with high melting point Castrol grease Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #184804 26th Apr 2013 12:22am
If you ever get it out, when (if) you put a new one in copper grease and then only finger tight when turning in.
They are only there as a safety item in case you have a wheel come off for any reason, it happens all the time Laughing , so that the disc stays in situ.
Totally un-necessary imo and frequently a nuisance. Thumbs Up
Post #184817 26th Apr 2013 7:53am
jerrytlr
France 2003 Range Rover Vogue 4.4 V8 Oslo Blue
When I had the same problem with my P38, I drilled the head off, and then once the disc was removed, the bit left behind was easy to remove with mole grips.
I didn't bother replacing them, waste of time IMO.
Cheers
Jerry
Post #184831 26th Apr 2013 8:36am
A few taps with a suitably sized cold chisel got it moving Very Happy
(Sorry about crap photos)
I seems it had only rusted in place around the outside edge of the plug as the thread was all still nicely copper eased:
Decided to put it back, but only finger tight, and copper eased the outer seat as well. .
Post #186738 5th May 2013 8:30pm
It will probably wash off after a few washes though Joe as the water will run past it when the alloys are on Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #186762 5th May 2013 10:47pm
