![]() | Home > Technical (L322) > Strange noise when air con on |
666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108 ![]() ![]() ![]() |
I have had my air con regassed doing a kwik fit no chill no bill. They reckon the system was leak tested but ok, they reckon its probably the compressor.
MikeG Member Since: 14 Apr 2013 Location: Netherlands Posts: 182 ![]() ![]() ![]() |
Having just gone through the replacement of the condenser and now suffering from a broken condenser fan I believe those connectors you are referring to are connected to the condenser fan and de pressure sensor sending the signal to the condenser fan... They took out my fan today since I'm going to Spain tomorrow and those connectors are now actually loose while they were connected before so almost sure they are linked to the condenser fan. Mike.
Thanks. I am going to Inspect those connections to see if there is anything a miss.
The electrical connections on the radiator all seem ok.
What I have understood about this during the last days is that the fan will start when you start the engine but it doesn't stay on all the time... This will depend on the pressure in the aircon system and a pressure sensor will send a signal to the fan when it's suppose to be activated to reduce the pressure...
I took the car to the main dealer. They described the shimmering noise as being the evaporator due to a lack of gas/fluid. They re gassed and added a dye in case there is a leak. They reckon the gas was low and it held pressure on their test. The car is now chilling and they have said I need to monitor performance In case there is a very small leak. They reckon most air con problems they deal with is lack of gas due to leaks. I am glad it's working at least for the time being and straight through its MOT again. 2012 4.4TDV8 VSE
