![]() | Home > Technical (L322) > [Solved -> FSR]Battery Drain Consumption identification |
Ibartsimp Member Since: 25 Dec 2012 Location: Bordeaux, France Posts: 197 ![]() ![]() ![]() |
Hi,
Alternator NOT OK! should be @ 14.5 volts with engine running .
yep, right, even if not clear I was more asking if my conclusion was ok |
Right, you have a voltmeter, but do you have an ammeter? This is what you need to look for a current drain. it needs to be connected in series with the positive battery cable, so one side to the battery +ve terminal and the other side to the battery +ve cable.
Ok, does my voltmeter also convert to ammeter?
Yes, the red cable goes in the left socket on the meter and you select the 10A scale. MAX 10 amps.
ok, will do tomorrow, thx a lot
Sorry, but if you want to check for drain down through the alternator you need to connect the ammeter as I described above.
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
If I managed to do a current draw test - ANYONE can!! |
Yes, the issue with me is my english.
The "jump stud" is marked "2" on the photograph below.
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
Remember an alternator will put less volts into a fully charged battery than a flat one. One day your life will flash before your eyes......................................make sure yours is worth watching!
ok, thx, a lot, I'll do that tomorrow and let you know. I also have a dead door handle to handle since tonight... courage! |
@ niceday, my ammeter only does 5A, will that be OK ? .
