![]() | Home > Technical (L322) > My first air suspension fault !! |
I have heard of hoses coming off the airbags (even on the forum). My bags were recently changed and it looks to me the hoses are relatively easy to do. The hoses are the "standard" plastic air hoses you see in industrial automation with the brass nut connection.
wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77 ![]() ![]() ![]() |
Sounds like it could be the air line going from the air compressor to the air tank. i think this hose goes through the off side wheel arch to the tank. it would prob start hissing when the compressor starts up to top the tank up. as you say, if it was the air spring then it would probably have dropped in that corner. also the hose to the air spring i would imagine would let it drop aswell. if its a standard size hard plastic pipe you get straight joining connectors that are just a push fit. these are used for the airlines on hgv's. you may be able to cut the burst bit out and use one to join the pipe back together again. would save having to replace the whole pipe. think i might have some lying around. would have to check the size though. if you ain't too far from me you 're welcome to one if you like. '04 td6 se
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
I am looking forward to checking tomorrow. Thanks for the offer wats39. Hopefully it is something easy as the weather is not brilliant for pulling a car to bits! Previously..
Aye, theres nothing worse than having to work on a car in the p |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Aye, theres nothing worse than having to lie on your back to work on a car in the p |
You're right... Gonna build a new garage ! |
Best do it soon before you're too old then |
Sorry but it's going to be chucking it down tomorrow, sunshine on Tuesday though, but you'll be too hung over to do anything |
Nicka2311 Member Since: 29 Dec 2012 Location: Scotland Posts: 51 ![]() ![]() ![]() |
I may only be 27 but I don't remember having this weather at all to work on cars outside? What happened to this Global warming we were promised? |
its a bag of tosh thats what |
Too busy today to look at the car... I will go easy on the juice tonight and get in aboot it tomorrow..
I guess that since you went easy on the juice last night and signed off at an early 3:30am you are now lying on your back underneath the FFRR sorting it out |
Haha... Correct... Just found it. There is a plastic connector that has come apart. I just came in to get the camera to take photos... So GIRFUY... |
