Home > Maintenance & Mods (L322) > Soundproofed my boot (part 1)
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
I decided to put some sound proofing down in my boot as there seems to be a resonance coming from there, probably due to the new exhaust, that wasn't there before. It was actually quite a simple job, even though it appears Halfords don't check their exchanges properly and sold me a roll of soundproofing that was missing a 4x18" section. Fortunately I had calculated that I would have had spare and I'd already unbolted the compressor at this point.
First step was to go through the boot looking for things that had particularly thin walls, fortunately this turned out to only be the floor of the spare wheel well. So I took everything out, unbolted the compressor and cleaned out the dust and debris inside.
Then I started working through the wheel well looking for areas that seemed especially resonant to a light tap with a spanner. I covered these using some Vibe Anti-Vibe Sound Deadening Material, which is kinda like Dynamat but cheaper.
I then went around again and found a couple of places that now sounded the most resonant and covered those. Eventually I had covered enough that almost everywhere was much more dampened than when I had started. Here's the final result:
You don't have to completely cover the whole boot with the stuff as it's there to reduce panel vibration which causes resonance. When my 12mm thick acoustic foam arrives (it should have been here today), I'll be covering everything over with that to completely deaden any noise being transmitted through the wheel well.
A little test drive afterwards confirmed it was definitely quieter inside the car now, and it was definitely worth the 2 hours it took to fit and the £50 of materials to do it. I've just got to adjust the resonance chambers on my exhaust to tune out a mild 2k rpm drone and my car will be quieter than when it had a stock exhaust while cruising, and fecking noisy when I want it to be.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #160441 29th Dec 2012 7:55pm
Mine already has that factory fitted
Post #160448 29th Dec 2012 8:29pm
Did the whole on my car inside, took ages but was well worth the whisper quiet effect... Just wish i had quieter fans now! Rolling Eyes
Craig Thumbs Up
Post #160449 29th Dec 2012 8:57pm
Iirc roofing felt is much cheaper and does te same job but is a bit heavier and not as shiny Smile
Good effort though Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #160452 29th Dec 2012 9:28pm
I used to cut pieces of Code 6 lead sheet and glue them in place with builders adhesive. Lot cheaper than Halfords and very effective.
Post #160453 29th Dec 2012 9:31pm
TheAllSeeingPie
Flashing tape / roofing felt is bitchumen based, the butyl stuff is nearly the same price per square metre as the Vibe stuff. Not heard of the lead stuff but it gets hot in there and I'd not be happy about a boot full of lead. Also the boot gets quite warm now so wanted something I know would stick and not stink.
Cam-tech, you're mental! If I could be bothered I probably would have covered it all, but since I have the acoustic foam coming soon, this is enough to reduce vibration and the foam reduces sound. Overall it should perform better and weight less, or at least that's the theory anyway. I'm also looking into different fans for the FFRR as I've noticed as soon as you turn them off the car is whisper quiet.
Post #160457 29th Dec 2012 10:11pm
Not with the price of lead nowadays, unless its "holy lead" of course Whistle
I did exactly the same thing on the Skoda as i thought the exhaust was a bit noisy at cruise. Used Dynamat. Dead easy to do and made a difference. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #160599 30th Dec 2012 8:50pm
You don't need much lead for it to be effective.
You only need patches approx 150mm x 75mm placed in the centres of panels.
You can still get a lot of lead for £20 without resorting to the Holy variety. Very Happy
Thinking about the wheel well and resonance, I have to question the need for any added anti-vibration pads to prevent resonance given the mass of the spare wheel
located in it and fixed in place by the threaded rod fixing.
I would have thought the wheel well and surrounding metalwork was more than adequately protected by the spare wheel against any stray resonance which may be why LR appear to have chosen not to treat against it.
Post #160629 30th Dec 2012 10:57pm
Ah, but LR didn't count on the AllSeeingPie fitting the "loudest" exhaust system he could come up with Laughing .
Post #160641 30th Dec 2012 11:25pm
TheAllSeeingPie
Just because I had the resonators removed on a straight through exhaust doesn't mean it's the loudest I could come up with ... oh er yeah I get your point! In fact I got told off by SWMBO earlier for driving "loudly" and she was 1/4 mile away in Cafe Nero!
I did a 100 mile journey today and it's dramatically reduced exhaust resonance in the cabin, so if you do want a seriously quiet car then it's worth doing.
This has been an experiment for me as designing the side-brance resonators for the exhaust has re-invigorated my appetite for physics. My uncle-in-law is a professional sound engineer (does soundproofing for cinemas and concert halls) and I've always been interested in his work.
Tomorrow I am hoping to adjust the side-branch resonators to remove the last of the motorway drone, although that's just me being picky as I am sure it's a lot quieter than it was before they were installed.
Post #160656 31st Dec 2012 12:12am
I think for a tunes exhaust yours won't be that bad as its still got the cats in it Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #160674 31st Dec 2012 1:13am
TheAllSeeingPie
The cats are 100 cell sports cats, so are roughly 1/5th the size of the LR ones and flow a lot better Wink
Post #160715 31st Dec 2012 11:33am
Cats are for pussy's! Wink I went the no cat route on my coop and legally as well Smile 3" turbo back exhaust with just a slightly muffled back box to avoid any boom. At full chat and on spool up the thing was monstrous and i only ran base boost Smile still the odd flame from the back proved it was worth it Very Happy
To this day people on the FCCUK still talk about the sound that exhaust made and all for a day of sitting in the middle of nowehere and spending £300 for a bespoke system to be made Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #160720 31st Dec 2012 11:49am
TheAllSeeingPie
New MOT regs state that a cat must be visibly fitted from 2012 onwards hence the teeny tiny ones fitted. Also it being a 4.2 litre supercharged motor there's no chance of it passing an MOT without cats. Smile
If I could have got away with a complete de-cat I would though. Oh and mufflers are for pussies, they deflect the air around. You wanted some fat resonators instead. Wink
Post #160810 31st Dec 2012 5:08pm
Some petrols AFTER 92/k reg can pass an MOT easily without breaking any regs and without a cat fitted Smile i know as i did it often enough and corrected examiners that were wrong Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #160814 31st Dec 2012 5:13pm
