Home > In Car Electronics (L322) > Ah well looks like the Battery is Goosed
Page 1 of 5 12345>
Went out earlier to start the Bat mobile and lo and behold the battery has gave up the ghost , so looks like a jump start from the power pack tomorrow and give the local stealers a call to supply and fit a Battery …. Rolling Eyes
Wife can't understand how i had the SC for 6 year without any battery problems and how the battery is gubbed on the TDV8 so soon …. Whistle Whistle
Post #157800 16th Dec 2012 3:05pm
frustrating that, maybe petrol dont need as much power to start than diesels.. ... - .- -.
Post #157802 16th Dec 2012 3:07pm
Buy one from Eurocarparts Mick Thumbs Up
Post #157804 16th Dec 2012 3:14pm
Here i've heard of the stories with people fitting batteries and ending up with skint knuckles and trying to get it to fit F Censored k that , anyhow thats what Mechanics are for … Laughing Laughing
Post #157806 16th Dec 2012 3:23pm
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
TDV8 does require more power than the V8SC to start but this shouldn't be an excuse. I would think battery is covered under 3 year warranty.
Post #157860 16th Dec 2012 6:39pm
If it's under warranty why spend the money when its their issue?
Is it the agm type mick as well as that's near the age they got swapped out isn't it? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #157861 16th Dec 2012 6:43pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
These modern "maintenance free" batteries seem to generally last longer than the old top them up with distilled water types, but when they give up, they seem to do so with little warning.
I had one in a Jeep a few years ago. Drove into town to go to the fair. Spent an hour there, and when I got back to the car, there wasn't enough juice to unlock the doors. According to the AA man it's not an uncommon situation.
The battery in my power pack jump starter thing has just gone the same way.
Post #157862 16th Dec 2012 6:45pm
[url] http://www.jaglanduk.com/index.php/home/de...es/flypage|ask/45-12v-950-amp-90ah-rc150-varta-car-battery.html?sef=hcfp [/url]
this seems to be the OEM battery (varta) at £70 plus postage. There is nothing that can't be fixed with a hammer😜😜
Post #157876 16th Dec 2012 7:17pm
spanner
I have 2 batteries on mine never had a issue since fitting the aux battery
Post #157886 16th Dec 2012 7:55pm
simon1233
Mick - As long as you aren't trying to fit one of the physically longer 110 Amp/hour batteries it is a doddle to swap the battery over, should take no longer than 5-10 minutes - although I have had battery issues the last few weeks so am quite familiar with the swap process now Evil or Very Mad
If you want the larger capacity 110 Amp/hour battery and less hassle on the fitting then there is a simple mod that I realised last week. The issue with the positive post of the battery and the explosive coupling charge comes about because you are not able to move the battery over to the right sufficiently to get the positive terminal on the post and the 'charge' located over to the side of the battery as there is some metalwork in the way. I considered removing some metalwork to accommodate the charge part of the positive terminal - but this seemed far too much like hard work (and i don't have the correct tools for the job anyway) and upon closer examination I realised that the base of the battery has plastic lugs on all sides to accommodate the various strapping solutions of the different manufacturers. I decided to remove the plastic moulding from the negative terminal end of the battery reasoning that this may afford me the extra couple of millimetres clearance that I needed. I would like to say that I carefully used a dremel to remove this plastic, but as I don't - a hardpoint saw did the job nicely Thumbs Up
Removing this bit of plastic means that there is now sufficient space to get the battery in and the terminals on without having to force anything Thumbs Up
I am guessing, but I think I may have invalidated my warranty with bosch, but if this battery goes again I will get the 100 Amp/hour one from eco which is the same size as the standard battery and will just drop in easily... Whistle
Post #157905 16th Dec 2012 8:45pm
Cheers for all the pointers gents unfortunately the car is just out of Warranty I am just surmising its the battery tho can't see it being anything else as it started no problems yesterday , will give the dealership a phone tomorrow to get a price to supply and fit anyway Thumbs Up
Post #157920 16th Dec 2012 10:05pm
I'm around tomorrow if you want one fitted Mick Thumbs Up
Post #157921 16th Dec 2012 10:09pm
Censored means I would need to clean and wash the motor if I was bringing it down to you Laughing
Post #157924 16th Dec 2012 10:18pm
Well I would hate for you to turn up with a minging FFRR in my street.
Offers there if you want
Post #157925 16th Dec 2012 10:21pm
BrianC
If you've got a halfords trade card you can get a battery cheap and they will fit it for a small fee
Post #157943 16th Dec 2012 11:27pm
Page 1 of 5 12345>
