![]() | Home > Technical (L322) > Location of light control module ? |
The LCM is located on the RH 'A' post, behind the trim panel. The LCM is connected to the vehicle wiring harness
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1456 ![]() ![]() |
Its essentially behind where the bonnet pull handle is.
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Thanks Fisha. Much appreciated.
Are the other indicators working on the right side? If so, then I doubt ts the lcm as I think it's a single output from the unit to all the lights ( will need to check ) on each side.
I am trying to find out if the LCM can be recoded as mine seems to have been changed at some point in time and is now showing a VIN mismatch. Will let you know when I find out. MY 2010 5.0 SC Galway green and sand interior!!
They can be re-coded I've read.
I can quite happily live with the "dot". I've kept the old LCM so it can be plugged back in and prove what's been changed if need be. In the meantime i'm slowly testing the PCB and diodes to see if i can find the fault. |
I am still chasing the re-coding, see if it can be done with the Faultmate. Maybe if you contact the IID boys if they have a method to do it with their tool. MY 2010 5.0 SC Galway green and sand interior!!
Had a look at the rave manual ... the circuit diagram shows that each corner and wing gets its own single supply from the LCM, so each circuit passes through its own transistor ( or part of a larger multi-circuit transistor )
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 ![]() ![]() ![]() |
In case it helps anyone,I had a problem with my lights, ongoing intermittently for over a year now, lights stuck on full beam, occasional loss of dash light, no indicators, then it would be fine for months.
