Home > Technical (L322) > ZF 6HP26 teardown
Page 1 of 3 123>
RRPhil
ZF 6HP26 teardown
First, a bit of background .....
Pierre Lepelletier is one of my heroes. He was born in 1928 and spent the whole of his career working for Ferodo (now Valeo) in France. At the age of 59 he took early retirement and then, two years later, filed a patent application for a new geartrain arrangement for automatic transmissions that could produce six well-spaced ratios using only 5 clutches, a Ravigneaux epicyclic and a simple epicyclic.
This was in December 1989. A few years later he had signed licenses with Aisin-AW (the world’s largest automatic transmission manufacturer), ZF, Ford, Jatco & GM allowing them all to manufacture transmissions using his geartrain system.
Why was his invention so important? Well, in ZF’s case - compared with the 5-speed 5HP24 unit that it replaced - the 6HP26 had 29% fewer parts (down from 666 to 470), was 44mm shorter (reduced from 697mm to 653mm) and weighed 12% less, despite its higher torque capacity and increased ratio spread. Most of the world’s OEMs switched to 6-speed transmissions as a result.
A colleague of mine was lucky enough to meet and have a chat with Monsieur Lepelletier at a conference a few years ago and told me that he’s a perfect gentleman. Now in his mid-eighties, I hope he enjoys a long and healthy retirement – and hopefully he’s made a few quid from the 20 million or so 6-speed transmissions that have so far been produced using his patented design!
The ZF 6HP26 transmission first appeared in 2001 in the 7 Series BMW, the year before the L322 Range Rover was launched, but since Ford had taken Land Rover off BMW’s hands in 2000, the L322 driveline development was frozen resulting in the Range Rover being launched with the already out-of-date 5-speed ZF unit in 2002. It wasn’t until 2006MY, when the Jaguar petrol engines were introduced, that the Range Rover finally caught up and the 6-speed unit became available. The diesel version had to wait yet another year for the TDV8 to be introduced before the infamous GM 5L40-E was finally abandoned in favour of the 6HP26.
Strictly, the Range Rover is fitted with the ZF 6HP26X transmission (the ‘X’ stands for external 4WD i.e. fitted with a separate transfer box) with part numbers starting 1068 020 XXX, the rear-wheel drive variant being the ZF 6HP26 (part numbers starting 1068 010 XXX) and the ‘internal 4WD’ version for Audi & Bentley being designated the ZF 6HP26A61 with part numbers starting 1068 030 XXX.
Anyway, on with the teardown ….
I saw this particular transmission on eBay, actually from a supercharged 4.2l V8 Range Rover Sport, with a starting price of £50 – and I turned out to be the only bidder.
After sliding the torque converter off its splines, and placing it safely to one side, I drained out the transmission fluid. The drain plug is at the back of the plastic sump pan.
Incidentally, the filler/level plug is on the right side of the casing, in a location similar to the 5-speed units
Sump pan removal next – there are 21 screws in all and it’s good to see that the head size has been increased to Torx T40, from T27 used on the 5HP24, to make the heads less likely to strip
These screws are tightened to 8Nm. ZF warn against removing the sump pan at fluid temperatures above 40 deg. C due to the risk of the plastic distorting at higher temperatures!
The sump pan then just pulls off
The filter is an integral part of the sump pan and the photo shows where the oil enters the filter at the very bottom of the sump and also the suction tube which engages in a hole in the oil pump housing
This particular sump pan/filter had never been changed, as revealed by the 2005 date stamp
The OEM is Filtran (as for the 5HP24)
and two sump magnets sit either side of the drain plug at the rear of the sump pan
The electrical connector sleeve is removed next, by first pulling out its retaining clip
and the connector sleeve will then come out of the casing
It’s easy to see, from the casing corrosion which has coated the two O-ring seals, why this is a very common source of oil leaks in the 6HP26 transmission.
The electrical pins on the Mechatronic module can be seen through the hole in the casing where the sleeve was extracted
There are ten screws in all (Torx T40) which bolt the Mechatronic module to the casing - seven long and three short - and these are easy to distinguish from the screws which hold the two valve block halves together which are only T27 and have a smaller head size
The rooster comb pin engages in a slot in the manual valve which also drives the slider on the (brown) potentiometer so that the controller knows which gear position has been selected by the driver
The Mechatronic module can then be lifted out
The Mechatronic module is a combined hydraulic valve block and transmission ECU. It also houses both the turbine and output speed sensors and also the fluid temperature sensor. There’s a risk that electro-static discharge could damage the ECU so ZF recommend that a ground strap is worn when handling it
This is how the underside of the casing looks with the Mechatronic module removed
Next, the bridge seal to the pump housing just lifts off
and then each of the four rubber jump tubes has to be extracted
In terms of length, there are two small, one medium and one large tube
The park lock engagement mechanism can be seen in the photo above and this is removed next, together with the selector shaft
So that’s it for the underside, next our attention turns to the front of the transmission.
The oil pump and stator support assembly is retained by 13 Torx T27 screws
and each of the (identical) screws is fitted with a washer with a rubber insert to prevent leaks
The assembly can then be drawn out from the casing
Next out is the A & E clutch assembly, which includes the front epicyclic
Followed by the B clutch assembly
To remove the static C clutch (& D clutch) housing, the large snap ring has to be extracted first
and it can then be drawn out
The two rectangular blocks in slots on the outside of the drum prevent the assembly rotating in the casing
Now the Ravigneaux epicyclic, together with the D clutch pack, follow
Which just leaves the output shaft
The intricate basket weaving around the annulus gear is actually the target wheel for the output speed sensor
Turning to the back of the transmission, the rear output seal is removed
to reveal a snap ring that retains the insert which locates the rear axial bearing
A couple of threaded holes allow extraction bolts to be screwed in to assist with its removal
So that’s just about it. The casing is now empty
A very simple process requiring no special tools.
Next step is to disassemble each of the subassemblies in turn. I’ll follow up with reports on progress with those.
Phil
Post #152170 19th Nov 2012 11:43pm
Thanks Phill, good read.
I always did think they should've used torx 40's instead of 27's. Laughing
Question for you. All these ZF 6 speeders, are they basically the same regardless of whether they're fitted to a BMW 116 or a Bentley W12?
Post #152177 20th Nov 2012 3:28am
SteveMFr
Site Sponsor
Very interesting as always, Phil. Learned a lot on this post - thanks.
And it is really good to see that there are still engineers who get their hands dirty!
Did this particular trans not have any probs? Seems that the six and up speeds are much more reliable than both the ZF and GM 5 speeds. Prices are considerably less for many late model transmissions. Maybe we need to rethink what it would take to actually do a swap. A CAN translation module would not be much trouble.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #152182 20th Nov 2012 6:52am
simon1233
Really interesting post Phil, I must say that I am fascinated/terrified in equal measure by the sheer complexity of these transmissions.
Looking forwards to the next updates Thumbs Up
Post #152184 20th Nov 2012 7:19am
ebajema
Excellent post Phil, wish we still had people like you doing the workshop manuals of cars in this way !!!
Thumbs Up Bow down MY 2010 5.0 SC Galway green and sand interior!!
Post #152189 20th Nov 2012 7:58am
Wow great write up Phil Thumbs Up
Post #152196 20th Nov 2012 8:17am
Awesome write up as usual Phil, I just wish I understood it all Big Cry
Post #152199 20th Nov 2012 8:53am
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
More detail can be found in this video:
Post #152226 20th Nov 2012 11:19am
Thumbs Up FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #152228 20th Nov 2012 11:24am
simon1233
The Rockwell video is fantastically illuminating, really cleared things up for me... Thumbs Up
Post #152235 20th Nov 2012 11:39am
madcima
Italy 2006 Range Rover HSE Td6 Zambezi Silver
Congratulations, nice service!!
Shocked
Post #152252 20th Nov 2012 12:13pm
mzplcg
Wow, just Wow !! Bow down Bow down
As for the sub-assemblies, are there any special tools needed for overhauling these?
I've rebuilt many a manual gearbox but never an auto. This makes me understand that they are not quite as scary as I thought.
Cheers. Dom.
Post #152278 20th Nov 2012 1:24pm
RRPhil
Thanks for your kind comments.
@KurtVerbose
ZF have a range of three 6-speed transmissions to cover different torque capacities. These started out as the 6HP19, 6HP26 & 6HP32 but were later upgraded to ‘2nd generation’ versions with higher torque capacities and renamed 6HP21, 6HP28 and 6HP34 respectively. The 6HP28 was introduced by Range Rover when the 5.0l V8 was launched for 2010MY. I’m afraid I don’t know what proportion of components are common to all of them.
@ SteveMFr
The history of the particular transmission that I’ve stripped is somewhat uncertain. It was listed as ‘working fine when removed’ but it’s sourced from an individual rather than a dismantlers so why anyone would wake up in the morning thinking “Hmmm, my gearbox seems to be working fine at the moment. I think I’ll take it out of my car and stick it on eBay for £50” I’m not sure. The fluid looks a bit contaminated to me so I’m thinking that I might find some issues once I start getting the subassemblies apart – we’ll see.
I agree that, with 11 years of use under its belt now, the 6-speed unit appears to be much more reliable than the 5-speeds (especially the 5L40-E!) it replaced. Certainly the ‘second-hand’ prices are a lot less. 5HP24s are generally priced around £1200 and the 6HP26s around £700 – probably a reflection of the fact that they’re much more plentiful, having also been used in the Disco 3, Disco 4 and RR Sport.
Interesting thought about retrofitting the 6-speed into the ’02-‘05/’06 models…
Unfortunately I don’t have speakers on my PC at work so I’m not learning much from the Rockwell video I’m afraid – but I’m looking forward to viewing it in all its glory this evening where I hope to receive full technology transfer.
Phil
Post #152307 20th Nov 2012 3:39pm
Thanks Phill. Thumbs Up
Post #152315 20th Nov 2012 4:05pm
Yes, it certainly covers one or two things that Phill has missed out.
Is it just me, or does anyone else hear 'doodie' when Americans say 'duty' - as in 'heavy doodie'?
Post #152316 20th Nov 2012 4:10pm
Page 1 of 3 123>
