Home > Technical (L322) > How to reset your Service Indicator
I nabbed this from another forum who's name will remain unmentioned but if you need to reset the service interval indicator here's a method than MIGHT work.
NB: No one can tell me why it works in some vehicles but not others.
With ignition turned off, press and hold LH instrument panel button in the dash area.
With button depressed, turn ignition key to position I.
Continue to hold for five seconds until "SIA reset" appears, then release the button.
It will flash "reset SIA 3600 kms" and "Inspection".
Press the button for another five seconds until "Reset" appears.
Switch the ignition off.
Good luck ! Cool Discovery 4 HSE
Post #783 20th Aug 2008 8:30pm
Larry
England 2006 Range Rover SE Td6 Java Black
Does this leave any trace on the ECU etc.? Don't want anybody invalidating their warranty.
Post #3669 11th Mar 2009 10:55am
Larry
Didn't work on mine!
Found this (below), is slightly different procedure, maybe this will work on someones car:
Resetting the Oil Service or Service Interval Message.
Ignition key must be “off”.
• Press and hold the trip odometer button in the instrument cluster (left button), and turn the ignition key to the first position (KLR).
• Keep the button pressed for approximately 5 seconds until one of the following words appear in the display: “OIL SERVICE, or “INSPECTION”, with “reset”.
• Release the reset button and press and hold it again until “reset” begins to flash.
• While the display is flashing, press the left button briefly to reset the service interval.
After the display has shown the new interval, the following will appear: “END SIA
Post #3813 14th Mar 2009 11:15am
pyramid1235
United Kingdom 2006 Range Rover Vogue Td6 Java Black
reset oil service in message display
Tried both methods of resetting my display but both do not work Sad Anybody know any other method?
Post #4179 25th Mar 2009 1:35pm
Larry
I haven't found any other way to get this reset on a MY06+ vehicle apart from actually paying someone with the Testbook/Testbook clone to reset it or by actually getting the service done.
Anyone know better???
Mine currently says 03.2009. What will it say when this expires? (I know I only have to wait a few more days, but I'm impatient! Smile
Post #4180 25th Mar 2009 1:52pm
pyramid1235
Thanks, had service done at an independant 4x4 garage £345 no vat ! he kept all the parts and showed them to me at the end he did a good job and cheap , i thought but he did not have a testbook he only ever resets them by the manual method but it would not work.. Anyone know how much should expect to pay a land rover dealer to reset??
Post #4181 25th Mar 2009 2:07pm
Andy
Where is this dealer based? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #5131 23rd Apr 2009 12:48pm
kin
England 2006 Range Rover Vogue TDV8 Zermatt Silver
Give these people a try, they may be able to reset it for cheaper than dealer.
http://www.a1-landrover-specialists.co.uk/
Post #5132 23rd Apr 2009 1:39pm
Pyramid,
I'm afraid that's the same issue I had with my local indy garage, I specifically asked them if they could reset the SI and they said yes. After the service they said they couldn't do it afterall but assured me of a fix. In the end they had to pay the local LR dealer the cost of a service to do it! Discovery 4 HSE
Post #5141 23rd Apr 2009 6:44pm
SteveMFr
Site Sponsor
Just as an item of information since this is a sticky: the service interval reset using the trip odometer button and the key only works on BMW based models. Jag based models (touchscreeen nav) need a diagnostic computer/tool. See the 'Blackbox Basic Bits' thread for more info.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #8632 23rd Nov 2009 7:34am
kb5
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
Found this http://www.roverupgrades.com/Range_Rover_Hidden_menus.html a while back I have done the oil change interval time which worked on my 04 V8 L322 . Wink
A good place to see how to do a blue tooth upgrade too.. (slightly off topic). Whistle
Post #11553 24th Jan 2010 12:43pm
andyw
England 2002 Range Rover HSE 4.4 V8 Zermatt Silver
hey all just stumbled across this sight just in case any one needs it
http://wiki.answers.com/Q/How_do_you_reset...ange_Rover
Very Happy 02 Range Rover HSE Zambezie silver 4.4
Post #12022 30th Jan 2010 10:06pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Of note on my BMW equpiied 03 TD6 (not touch screen) you need to have the drivers door open sufficiently that the "Key in Ignition" warning pops up otherwise if you sit with the door shut - zilch.
I've had to reset mine as the lad at the main agent couldn't manage to remember the procedure - that said I paid for the cheap service. Only hope he remembered to put the sump plug back Evil or Very Mad 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #31129 7th Oct 2010 12:42pm
4rovers
United Kingdom 2002 Range Rover Vogue Td6 Buckingham Blue
no luck on my 2002 model, will try with the door open sometime soon.
the other instructions I have seen ask if the date was exceeded, but I don't see those questrions, aybe they are not displayed on the RR display as it is too small or something?
will keep trying
Post #46777 20th Jan 2011 3:48pm
dan_uk_1984
will keep trying
Slightly different info here:
http://www.fullfatrr.com/wiki/Secret_Codes
Only slightly
Post #46791 20th Jan 2011 5:12pm
