Home > Maintenance & Mods (L322) > Jacks
Rambles
Jacks
We all know the scissor item supplied is not fit for purpose.
Can anyone suggests a bottle jack?
they seem small enough, and can easily stow in the boot and don't cost that much.
Halfords do a simple bottle jack:
http://www.halfords.com/webapp/wcs/stores/...yId_255207
but i am not sure if the lifting range is enough.
anyone know what the lifting range needs to be?
Post #148581 28th Oct 2012 6:10am
If you have a quik search on here there is a thread I contributed in which lists the one I got.
Yes it's overkill with its 20tonne limit but it lifts the ff in now time, is a 3tier lift and has a screw out section to help reduce pumping time. I can't fault it at all and at full stretch the wheel is about 1/2' if not more off the ground so easily does the job required and was £35 iirc so cheaper than a trolley jack, fits in the boot easily enough for use instead of the scissor jack. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #148584 28th Oct 2012 7:29am
http://www.fullfatrr.com/forum/topic9955.html?highlight=jacks
loads more found via search.. ... - .- -.
Post #148585 28th Oct 2012 7:30am
Rambles
Kingpleb
so something like this?
http://www.amazon.co.uk/Draper-55124-High-...amp;sr=8-6
Post #148591 28th Oct 2012 8:09am
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
I modified this one:- it has a 570mm lift
http://www.fullfatrr.com/forum/topic14177.html
Post #148661 28th Oct 2012 4:35pm
A1GSS
Plenty more in stock, he says... Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #148688 28th Oct 2012 6:11pm
Rambles, Yes thats the kind of one but double what i paid. Fair enough its brand new like but exactly the same as mine, in Blue and a different sticker on the front Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #148695 28th Oct 2012 6:48pm
http://www.ebay.co.uk/itm/20T-Hydrolic-Air...3a7b223351
http://www.ebay.co.uk/itm/HYDRAULIC-BOTTLE...27cc4d6a7a
http://www.ebay.co.uk/itm/20-TON-HEAVY-DUT...2a24eed850
http://www.ebay.co.uk/itm/20-TONNE-HYDRAUL...4abd9efd06
The last one is the exact one i have. At full extension the wheel is miles off the ground! Trust me it IS overkill but has a fair old safety margin built in, pumps up quick and goes down quick.
Only downside is the pressure release part doesn't perfectly fit the handle slots. but its easy enough to turn it anyway at an angle Smile Just have to get my dad to reslot mine at some point! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #148696 28th Oct 2012 7:01pm
Pitsnow
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
Just one more option from Dapper:
http://www.drapertoolbox.co.uk/draper-high...c-0-129838
From 256mm to 610mm, 4t for 46.46 new.
Post #148736 28th Oct 2012 11:47pm
Here's a link to mine with another 3" of lift to go, probably more if I recall properly though I have only once ever had to fully extend it and that was on an off road jolly when it was sat lower than the wheel!! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #148863 29th Oct 2012 7:19pm
