Home > Maintenance & Mods (L322) > Bottle Jack Modification to replace Scissor Jack
Page 1 of 10 12345678910>
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
I know this has been discussed to exhaustion on here but just wanted to share an idea i had to solve the emergency jack problem if you were unfortunate enough to get a flat.
I’ve looked at many Bottle jacks but never felt they extended far enough or were true to the jacking points on the FF RR and for some time I’ve been carrying a thumping great trolley jack that lifts to 530mm which is sufficient to get the wheels off the ground if required to change the wheel but its a pain in the back of the car...
So having checked the height/clearance to the 4 jacking points I found that some vans still use bottle jacks like the 2.5 ton Bottle jack off a Mercedes Sprinter that extents to a massive 570mm but without the bulk of a 4,5 or 6 tonne bottle jack body. The other reason i looked at this one is it appeared to have a removable shoulder that could be replaced with a bespoke BMW jacking plate.......that was my plan anyway....
So after receiving delivery of the jack, found one new for £26.01 delivered on flea bay I then sourced a BMW jacking adapter again from flea bay and set about joining the two together in glorious matrimony. You need to remove the old shoulder from the top of the jack with a 4mm punch then with some careful drilling of the jack adapter, drill a 16mm hole 16mm deep in the base of the adaptor to fit over the top of the jack. Then drill a 4mm hole drilled through the base of the adaptor to fit a 4x40mm roll pin which is longer than the one removed and there you have it, a bespoke 2.5 t bottle jack that fits in the BMW jacking points.
It’s much more stable than the scissor jack and due the BMW adapter it feels more secure than a standard bottle jack as they could slip at the point of contact with the car
I’ve added a few pictures of the result........even found a small box to keep it all tidy
Post #147008 19th Oct 2012 3:17pm
When under the car take the blocks off, they are only a thick rubber/plastic and the proper mount and slot are underneath for long term jacking Smile Just waxoil it a little to keep it from rusting Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #147017 19th Oct 2012 3:45pm
nice.. Thumbs Up ... - .- -.
Post #147022 19th Oct 2012 4:03pm
Anybody wanting a Merc Sprinter bottle jack as above, 570mm lift.
£26.00 delivered.
Just ordered one myself.
Bottle Jack
Post #148669 28th Oct 2012 6:32pm
And I just got the last one, cheers.. Now to find the BMW end piece. Very Happy Previously..
Post #148671 28th Oct 2012 6:38pm
nbunney
Could you not just cut / grind the existing shoulder to fit?
Post #148694 28th Oct 2012 7:46pm
Andy
More here- I've just ordered one
http://www.ebay.co.uk/itm/2-5-TON-HYDRAULI...3ccd7a3437
Just out of interest - Where are the jacking points that this adaptor slots into?
Post #182280 10th Apr 2013 8:59pm
Underside of the black plastic sill trim. Thumbs Up
Post #182291 10th Apr 2013 9:48pm
supershuttle
I've just nipped over to Bolton and picked one of these up - substantial piece of kit and it includes a bag of tools. He's got plenty left and he's a decent bloke. Very Happy Geoff
Post #182398 11th Apr 2013 2:51pm
Andy
Mine arrived today. Fits nicely at the side of the spare wheel. Just need to get a BMW adaptor now and job done!
Post #183053 15th Apr 2013 6:15pm
I never got round to puting the BMW end on it as it does fit just nicely, diagonally, in the jacking point. Previously..
Post #183055 15th Apr 2013 6:37pm
Andy
Wouldn't that put undue pressure on those points though, as its not sitting flat in the square?
Post #183178 16th Apr 2013 11:29am
ebajema
Does anyone have a drawing of the little alu block that sits on the top. A drawing with dimensions that I can send to a machinist to make it for me ?? MY 2010 5.0 SC Galway green and sand interior!!
Post #185443 29th Apr 2013 11:31am
What about just grinding the original piece flat?? Would there still be enough meat left on it? I think so. Previously..
Post #185447 29th Apr 2013 11:45am
If you cut it down i think it would be too big to fit in and would overlap the the slot.
If someone who has one could measure the dimensions it should only take a few mins to rig up a drawing Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #185450 29th Apr 2013 11:50am
