![]() | Home > Technical (L322) > Aux Heating on Menu |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7916 ![]() ![]() ![]() |
In order for the FBH to come on using the timer function, do you have Aux Heating as an option on the screen as well as Aux Ventilation? As I only have the latter............
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 ![]() ![]() ![]() |
Yes unless you have a remote for it. RANGE ROVER 04 TD6
I don't have a remote, or the Aux Heating option, so that would leave me a bit scuppered then.
Some diagnostic tools can re-enable the Aux heating selection on the menu. .
For the remote to work, you will almost always have the park heat function in the menu (I am not 100% sure what the exact wording is in English as mine is in German ![]() The MKIV nav is on a different bus and has next to nothing to do with the aux heat function other than displaying on the same screen. As Joe said, it can be activated with an appropriate diagnostic system. AFAIK, the complete list of diagnostic systems with which it is possible to do this is: - Our IIDTool <£300 purchase price - Blackbox MSV ~£1000 - OEM Land Rover T4 £££... Once activated, you can add the remote receiver and the remote function will work as well. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
Can't recall ever having it, but without putting the Mk3 nav back in, can't be sure. Assume its stored somewhere in there as to whats what ?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35656 ![]() ![]() |
tbh mark by the time you find a garage and make the time to go there , you might as well buy an IIDTool which will be more beneficial in the long run and you can do so much more with it.. ... - .- -.
Mmmm
mines a touch screen so i cant help with pics but is there anything in your manual re this ? ... - .- -.
My screen isn't much like the manual, as I have the BMW Mk4 Nav.
Select it and press the button.... but hold on tight |
Hi Mark,
This is why I gave you a list in the post above: AllComms is not included and - unless KiwiJochen, the Navcoder developer, changed a lot on his program - neither is Navcoder. If you are hell bent on getting park heat w/o paying anything and have time to blow playing with PCs and searching the internet (and have no scruples about DLing and running illegal SW), search for NCS Expert. That can do it as well. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) Last edited by SteveMFr on 12th Oct 2012 4:48pm. Edited 1 time in total |
Ah right. I knew the screen changed when I changed the nav, so just figured it was the brains as it were.
edited my post above |
