Home > Technical (L322) > Genuine Brake Part numbers- TD6 & 4.4V8 models
I had to find this out as mine is a facelift model and everyone seems confused as to which brake pads to use.
A LR Dealer will give you a definitive answer from your reg number or VIN but this is what I found out.
The front and rear brake pads were changed from chassis number 58******* onwards. You'd think they'd be more expensive but they made them cheaper for once. The difference is they are smaller.
I only have the rear pad part numbers at the moment
L322 02-05 MY Pre 58****chassis number
Part No. SPF000120
L322 06MY->
Part No. SPF000140 Discovery 4 HSE
Post #723 1st Aug 2008 10:47am
The Flying Scot
Scotland 2012 Range Rover Westminster 4.4 V8 Fuji White
Hi
I change both front and rear pads a couple of months back..including new wear sensors. I have a 04 Plate and the genuine part numbers were..
Front
Pads = SFC500050
Sensor = SEM000012
Rear
Pads = SFP500120
Sensor = SOE000011
Hope this helps 2011 Range Rover TDV8 4.4 Vogue SE
2007 Range Rover TDV8 Vogue (Sold)
2004 Range Rover Vogue TD6 (Sold)
Post #4910 13th Apr 2009 2:30pm
Ivan
Ireland 2005 Range Rover Vogue SE Supercharged Zermatt Silver
Ferodo nos. for an '05 S/C with Brembos
Front FDB 1996
Rear FDB 1613
About £40 a set, depending on where you buy
Ivan FF RR S/C (Gone)
TVR Chimaera 500(Gone)
TR7 V8
Post #5431 6th May 2009 3:09pm
Update: All Genuine Parts & Prices
These parts are for facelift cars (TD6 & 4.4V8), from 05 registration onwards, 06MY onwards. These are NOT for Supercharged 4.2 Brembo brakes or TDV8 models.
Prices are genuine Dealer Parts department. ALWAYS ask for 10% discount ontop, they never say no.
Front Discs: SDB500182 £48.67 +VAT each
Front Pads: SFP500010 £60.64 +VAT per set
Front Sensor Wire: SEM000012 £14.61 +VAT
Rear Discs: SDB500202 £48.67 +VAT each
Rear Pads: SFP500140 £44.00 +VAT per set
Rear Sensor Wire: SOE000025 £8.27 +VAT Discovery 4 HSE
Post #5496 11th May 2009 9:53am
2002-2005 Brake Disc Part numbers - Front & Rear
2002 to Vin range 5A999999 TD6 & 4.4 V8
Front Discs: Genuine Part Number SBD000201
Rear Discs: Genuine Part number SBD000211 Discovery 4 HSE
Post #5501 11th May 2009 11:15am
Andy
There is a company on ebay selling new discs and pads quite reasonably. Front with pads £68, rear with pads £54. delivery around £10 per item. I've just emailed them to see how much for the lot in one delivery. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #5919 1st Jun 2009 11:54am
more importantly check the brand and where they were made, i've been told to avoid chinese made. Discovery 4 HSE
Post #5924 1st Jun 2009 1:30pm
dan_uk_1984
I tend to go for cheaper (£20 a set) pads, my theory is that being made of what I presume is out of date cheese (although, does cheese ever go out of date or does it just get more expensive?) they tend to wear about 25% quicker than OEM pads. This means the discs last a lot longer.
I've currently got Bearmach on the front and Mintex on the back. These are now £16.99 at Island 4x4.
I actually think they stop better than the OEM's, but that may be my imagination. But they do throw out a whole load more brake dust than the OEM's. I notice that Island 4x4 now do the pad wear sensor too for £9.99 - Barjin!
Post #5927 1st Jun 2009 2:08pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Just had rear discs + pads and front pads fitted on my 2006 56 Plate FFRR 3.0d and parts listed as:-
SOE500030 - (TP) Sensor Assembly - front @£15+vat
SDB500202 - (TP) Disc - rear @£103+vat the pair
BDA0150 - Brake cleaner @ £5+vat
SFP500010 - (TP) Pad - front @£57+vat (actually ferodos)
SEM000012 - (TP) Sensor Assembly - rear @£18+vat
LR016808 - (T) Kit - Brake Lining - rear ferodo pads?? @£47+vat
From this topic, itl ooks like I could have maybe done a bit better on the prices but they seem comparable.
The LR01608 kit above is the only thing confusing me, I'm assuming it is the rear pad set (SFP500140) with some other ancilliary stuff bundled together. Anyone know? (I should have asked the Service guy).
Steve Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #5945 2nd Jun 2009 2:05am
Andy
the discs are from Bearmach - www.bearmach.com - and the pads are mintex
Link to ebay auction:
Rear: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...0152207717
Front: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...0199232381 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #6914 13th Aug 2009 7:26pm
RRVSE
Just out of interest, both my rear discs rusted about 4 weeks after they were fitted (the hub part) and I complained to the dealer as I reckoned they looked unsightly and asked where they were sourced from and was told they were standard LR issue (so can only assume LR are using another supplier). I mentioned that the ones they took off weren't rusty and nor were my front disc hubs and they had both been on for almost 3yrs!! As I got no joy, I'm now planning to paint the hubs with some high heat aluminiun paint I used on my other cars exhaust manifold.
Steve Steve
Post #6962 17th Aug 2009 1:59am
