Home > Maintenance & Mods (L322) > Interior lights to led
Been changing all the interior lights to led today and came unstuck with the interior roof / map lights.
The 5 smd 501 bulbs I have bought for everywhere else don't fit into the roof / map lights as the smd section is too large a dia to fit thro the hole in the light fitting. Big Cry The bulbs fit into the holders ok.
Could someone who has converted to led point me in the direction of 501 led bulbs that will fit correctly.
Thanks.
Post #141935 19th Sep 2012 12:57pm
make the holes bigger, i did.. Thumbs Up ... - .- -.
Post #141937 19th Sep 2012 1:09pm
That crossed my mind, but I was looking for the simple solution. Smile
May have to resort to that.
Post #141941 19th Sep 2012 1:16pm
RCusden
Wales
did you buy a complete kit or just buy the amount of bulbs required as it is something on the list of mods to do
roger
Post #141944 19th Sep 2012 1:23pm
I just bought all the bulbs, two types fit everything bar the roof / map lights.
Just looking to get the right bulb for them.
Post #141948 19th Sep 2012 1:27pm
Tuts
I 'shaved' the collar off of the led with a Stanley knife Wink 2003 Vogue 4.4 V8 Java Black
Post #141968 19th Sep 2012 4:10pm
daveo
the easy way is to put them in from the outside Thumbs Up V8 facelift Range Rover Autobiography 22" wheels.
Post #141970 19th Sep 2012 4:26pm
Thats the way to do it Exclamation
I can order the bulbs for the two fittings now I know what works. Thumbs Up
Thanks for the suggestions.
Post #141974 19th Sep 2012 5:19pm
Just in case anyone else has a mind to do this mod these are the bulbs required and links to the ones I used.
501 bulbs
Tailgate lights x2
Roof interior light x2
Upper footwell x2
Door puddle lights x4
501 led
501 bulbs
Map reading lights x4
501(map)
39mm festoon bulbs
Luggage area light x1
Glovebox light x1
Lower footwell lights x2
Festoon led bulbs
While I was at it I also bought these for the number plate lights x2
39mm canbus festoon
I didn't bother with the vanity lights, don't use them. Smile
The above is for a 2004 car so other years may vary but it gives an idea of what is involved.
I did notice that my handbook indicates 501 bulbs in the lower footwell lights but mine are definitely 39mm festoon.
I hope this is of some use.
Post #141990 19th Sep 2012 6:17pm
DMRR
Er guys....you just have to pop out the roof fitting, unscrew TWO screws and fit the 'LEDS' .. then screw it back together. Simple. No need to butcher the poor thing!!!
I have 20 SMD units in mine.... Whistle Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #142015 19th Sep 2012 8:51pm
