![]() | Home > Technical (L322) > Door Card |
markdotreed Member Since: 05 Sep 2011 Location: Ropley Posts: 741 ![]() ![]() |
I've read just about every thread on door locks not working. My passenger door will not unlock with either the key or the internal button so I thought I'd have a go at lubricating it myself.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
Well, not a great lot of use to you, but I replaced the speaker on a mates 4.4 petrol, and he really struggled to get that connector off. Very tight.
Teased it with a small screwdriver for a while and it wasn't going anywhere..... Will take a picture of it later.... Regards
Had another go at it last night. Worked out the plug (thanks anyway Craig) but after loads of fiddling and half a can of WD40 nothing is any better.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Why book it in Mark? Your almost at the latch you would need to change! Disconnect your battery, undo the four bolts holding on the door airbag and secure it out of the way (with cable tie or sticky tape) then pull back the black inner cover, remove the 3 or 4 torque screws holding the latch to the door (open the front door, where your childlock would be on the rear door you will see the torques bolts around the latch)
OK.... I had the airbag off and I had the inner off....
Is this any use ?
No, I didn't.... Thanks Regards
Its all in RAVE, which you can download from the Wiki..........
Ok... Old door latch is off, Keith Gott had a new one in stock so I went and got that, little bit of transferring of parts around and about to do the refit. Will put some pictures ip later Regards
And....it's all working again..... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35652 ![]() ![]() |
down to the pub then... |
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Fell inside the door cavity |
