Home > Technical (L322) > Magna Steyr DD295 Transfer Box Teardown
Page 9 of 9 <123456789
Halim
Malaysia 2010 Range Rover Supercharged 5.0 V8 Nara Bronze
Hello guys, according to Sussex autos, there are 2 types of input shaft. See below the shaft from Sussexautos, slightly different from Phil's photo above, which is what I need. I've checked with TCP (Transfercase Parts), they also have same thing...mmmm, its getting very challenging..appreciate any thoughts from anyone...thank you.
Post #681759 3rd Jan 2024 8:14am
RRPhil
The information on the Sussex Autos website certainly indicates that there was a design change from 2011MY and that the earlier input shaft isn’t interchangeable and, worse still, is no longer available.
JPAT list two different input shafts, with the earlier one having a JPAT part no. N901 29 04. It may be worth asking if they can still supply the earlier shaft?
The part numbers do cross-reference with those on MicroCat. Note that the transfer box part numbers LR035617, LR045477, LR049160, LR052611 & LR089531 mentioned in both the Sussex Autos and JPAT data are for the L405 Range Rover from 2013MY onwards, which continued to use the Magna Steyr DD295 transfer box.
One thing I did notice in this JPAT diagram is a tensioner/guide for the Hy-Vo chain
This certainly wasn’t fitted in the transfer case (IAB500280) which was the subject of my teardown.
Also, according to the JPAT catalogue, the Hy-Vo chain itself and its two sprockets seem to change part numbers at the same time that the input shaft changed.
If anyone has any further information on the 2011 design changes it would be very gratefully received.
Phil
Post #682012 6th Jan 2024 4:57pm
kevinp
Hi Phil, how far do you think I should be able to rotate the front output flange before the rear one would move?
I realise there will be some slack in the chain but wondering if mine is excessive that could be causing a 'bump' when starting off after coming to a halt. Thanks.
Post #691891 4th May 2024 12:22pm
RRPhil
Hmmm. I’m afraid I don’t have a transfer box here to test it on right now, but I would say that the free play isn’t just the chain slack because the backlash in the bevel gears of the centre differential also has to be taken up before the drive between the two flanges becomes solid. Approximately how many degrees of rotation are you observing?
Phil
Post #691916 4th May 2024 5:51pm
kevinp
I'll have a look when I'm a bit more able Phil thanks.
Post #691922 4th May 2024 8:06pm
kevinp
Sorry for the delay Phil.
The front output shaft can rotate 12.5 degrees before the rear one moves.
Thanks.
Post #694832 21st Jun 2024 12:30pm
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
I think mine could have a similar number of degrees of difference between the front and rear output.
Wondered if it could be a stretched chain as well.
Sometimes there's fairly soft "thump" I noticed when something's taking up slack.
Not from a standstill but rather taking up drive from engine braking.
Post #695105 26th Jun 2024 4:51pm
