Home > Technical (L322) > FFRR '02-'05 Suspension Heights
Further to a previous post about this, I thought I would tabulate the ride height measurements for various wheel sizes. The hub centre measurements come from RAVE, the rest are calculated with measurements from my own sets of wheels. Your wheels may have different rim to rim measurements. It is much easier to measure from the bottom of the rim than the hub centre, hence why these figures are included.
My calculation is simple: measure from bottom of rim to bottom of wing, divide by 2, then add the hub centre measurement, and any height setting amount is then added or subtracted.
When setting suspension heights, the assumption is that everything is in perfect working order, and that you are on completely level ground, for example on off road height the cross link valves come into play and may level the car, thus changing the heights. Or you may have one sensor which is working fine, but for what ever reason is sending the wrong signal back to the ECU, so you may have to manually adjust measurements when setting suspension heights with your chosen tool.
So, here it is:
For info:
Offroad heights go up by 60mm at the front and 50mm at the rear
Access height drops all corners by 40mm
Motorway height drops all corners by 20mm
More than happy to argue the toss about this, but this should serve as a useful guide, if nothing else Smile .
Post #128760 1st Jul 2012 2:49pm
n1cktdv8
What should I be going for with 21's on ?
TIA Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #365129 3rd Jan 2016 8:32pm
the 21'' arnt a standard size for the L322 Nick so i doubt if there any figures... ... - .- -.
Post #365133 3rd Jan 2016 8:37pm
Use hub centre measurements, they stay the same Wink
Problem is picking your spot! however LR allow a 10mm margin of error in any case Thumbs Up .
Post #365161 3rd Jan 2016 11:19pm
