![]() | Home > Technical (L322) > Blocking protection problem - front wipers |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1003 ![]() ![]() |
I’ve been having a problem with my front windscreen wipers just stopping for no apparent reason while they’re switched on (I don’t mean the ‘intermittent’ function – this is in both normal and fast ‘continuous’ modes).
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Just because LR have never sole one before doesn't mean they can be faultless. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
Ive seen two with similar complaints... Both needed replacement BCU's...
Okay, thanks. In that case I’ll try the new relay first, now it’s on order, but it sounds like I’m going to end up needing a new BCU. My BCU has been superseded twice by Land Rover since 2003 (from YWC000921 to YWC000922 and now to YWC000923) so I’m trying to find out from Blackbox Solutions if my Faultmate MSV-2 will allow me to get the new hardware & software versions to work on my vehicle.
JonP Member Since: 11 Jul 2011 Location: Surrey Posts: 51 ![]() ![]() |
Hi Phil
Thanks Jon - that sounds encouraging!
Just a quick (& hopefully final) update. I’ve used my wipers for several hours now since fitting the new relay and not had any issues at all so I’m confident that, like JonP, this £6 part was the problem
Not like you Phil (says the man who bought a new transfer box motor that only proved he didn't need one!!) .
thatgirl101 Member Since: 28 Feb 2014 Location: London Posts: 45 ![]() ![]() ![]() |
I've just come back from a trip to France in our L322 and experienced a similar problem - the wipers just stopped randomly and only turned back on when we restarted the ignition.
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 ![]() ![]() ![]() |
ywb000060 ----------
Hi,
Thanks - all done. And like the poster above, the relay that I took out quite obviously had some loose parts in it. Hopefully that will fix the problem - I need a nice long rainy drive to test them out! |
^ Careful what you ask for unless you fancy gathering 2 of every animal on the planet. |
