Home > For Sale & Wanted > GAP diagnostics EAS control. Range rover L322 02-05
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
Now i have sold my Range rover i have decided to sell my EAS control gizmo. Fantastic bit of kit used a couple of times on my RR to clear faults and alter ride height
For a 2002-2005 model only and will need an additional VIN unlock from britpart as it is locked to the VIN of my old car
more details-
http://www.gap-diagnostic.com/products/eascontrol.html
As well as doing full diagnostics on the air suspension system it will also read and clear faults in any other system including engine,gearbox,airbag,transfer box,steering,abs etc. etc.
Only used a couple of times and still with box
Britpart part number DA6420
£120 ono inc postage
Paul Thumbs Up Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #118382 19th Apr 2012 11:07pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
Is it the full IID tool or eas only?
Also u might want to find out how much it is for another unlock as if it's dearer when added to what ur looking for it might work out better/cheaper for people to buy new.
Hope that helps Thumbs Up
Post #118383 19th Apr 2012 11:27pm
marsie
I contacted Steve at GAP to ask him about the vin unlock and he said they were easily available through any britpart reseller but didnt say how much. I am open to offers on this as it wont work on my defender Mr. Green . Failing that i will stick it on ebay
Paul Thumbs Up Paul
Post #118575 21st Apr 2012 11:26am
Reformed
Unlock codes are £55 here;
http://www.4muddyfeet.com/shop/index.php?cPath=2025_2029 Reformed
Post #118578 21st Apr 2012 11:36am
marsie
Thanks for the link Reformed. Price Reduced due to info posted by Reformed
£120 ono delivered Paul
Post #119222 26th Apr 2012 7:53pm
frapa02
Do you still have the GAP eas control device available and do you have the reduced price to cover the unlock cost?
I have the dreaded 'EAS susp inactive' message and I think it is because the battery was a bit low.
Cheers, Paul.
Post #119602 29th Apr 2012 9:39pm
marsie
Yep its still for sale. Reduced to £120ono to take into account the vin unlock
cheers
Paul 07989677452 Paul
Post #119725 30th Apr 2012 9:14pm
frapa02
Just to let you know that I went for the All Comms from RSW Solutions after much consideration. This is highly recommended and can deal with many of the ECus in the MKIII / L322. My suspension issues were resolved but I did need to pull the EAS fuse for a few minutes to get it to work properly.
Paul.
Post #121260 10th May 2012 11:17pm
marsie
Ok, no probs. thanks for letting me know. For those asking this unit will do the following----
Recalibrate air suspension and allow you to alter the various ride heights if you require or reset factory settings,also allows you to store you favourite settings. Also reads and clears faults in air suspension system and canread temps/pressures/heights
Read and clear faults in-
air suspension
engine ecu
gearbox ecu
transfer box ecu
instrument panel ecu
air conditioning ecu
air bag ecu
headlight ecu
alarm ecu
abs ecu
steering ecu
etc etc.
plus its only about 2" square and needs no laptop or power so small enough to keep in the glovebox at all times Thumbs Up Paul
Post #121266 11th May 2012 12:32am
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
Marsie,
Would this work on a 2006MY TD6 Touchscreen model i.e. the post-facelift model?
Thanks African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #122350 17th May 2012 10:54am
marsie
No sorry,i believe its a different system on 05 onwards although GAP do the same device for you car
Paul Thumbs Up Paul
Post #122354 17th May 2012 12:11pm
Andy
I'd be interested but it's paying £55 to have it re-assigned that grates me. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #122510 18th May 2012 7:10am
piersie
England 2003 Range Rover Vogue Td6 Epsom Green
PM Sent. Thumbs Up
Post #122528 18th May 2012 10:28am
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
wow marcie, did they not take the gismo when you part exchanged your RR for less money as the sale we agreed upon? Evil or Very Mad
Post #122652 19th May 2012 2:11pm
