![]() | Home > In Car Electronics (L322) > Headlamp Wiring Advice Needed? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6418 ![]() ![]() |
Need to hack into the headlamp wiring to set up my fogs as DRLs. There are warnings everywhere about the 25000 volts on the bi-xenons so want to make sure I get this right!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35599 ![]() ![]() |
i wish i took notice of my set up tim.....stick a multimeter in the headlamp plug and do the usual like turning on the ignition and read the readings .. ... - .- -.
i'll have a look at mine tomorrow... |
Slight hi-jack - Can you retrofit bi-xenons? My TDV8 has standard halogens |
But what about the 25000 volts ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
The description of the wiring and feeds for halogen and bi-xenon appears to be the same, but i don't know enough about it to say yeah or nay. Suggest start a new thread for this? ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
Really? My tdv8 has xenons and I thought they all did ![]() Are you talking about the separate high beams? If so, I believe it is normal for these to be halogen still - something to do with the fact that xenon doesn't come on instantaneously, important for flashing the lights - the main beam shifts it's pattern to be full beam slightly later |
In all L322's from 02-08 you can get both Xenon and Halogen headlamps depending on spec... Only the 09my> that comes with Xenon headlamps across the range...
Thank you for enlightening me, Craig - to work!! ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
tim,
ok, had a look but its all taped up pretty well but what i can see is that the ignition is green/brown and the headlight on feed is yellow/green.....hope this helps.. ... - .- -.
LH side (Passenger side RHD)
Is there an "easy" way to put the headlight unit back in. Seems you have to fiddle and struggle for 15 minutes, then suddenly it slots into place |
15 minutes is the easy way tim... |
