Home > Maintenance & Mods (L322) > Front Door Exterior Window Surround
mjdronfield
Hi all,
Does anyone know how to remove the front door exterior window surround ?
The matt black 3 sided frame thing on the outside of the windows ?
My front passenger side has rust coming through it and is looking tattty compared to the rest of the car.
I've had a look on RAVE, and can only see instructions for the inside trim.........
Thanks
Mark
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #113557 17th Mar 2012 4:06pm
ambulancekidd
Scotland 2005 Range Rover Vogue Td6 Oslo Blue
I'm not sure how this surround is removed on the L322 but on Discovery models you need to remove the door card as well as the inner door protection cover. The door top can then be unbolted & removed with an upwards movement.
To stop the corrosion happening again I always use Morrisons (the supermarket) own brand shoe wax shine!
Do not use the scuff cover but the shoe shine wax does exactly what it says on the box It blackens shines & adds wax with the usual benefits of protecting against rust. I've been using this stuff on the blackwork of all my cars for years including the tyre walls (but NOT the tread) & people often ask me what I use to get such a good finish. It lasts on average for about 6 months but the more you apply the deeper the shine.
Try it, it certainly works for me...
Robert.
See below.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  The reason women's minds are cleaner than a mans mind is that women change their minds more often!
When women say fine a mans in deep doodoo as fine has so many meanings.
Post #113695 18th Mar 2012 5:16pm
mjdronfield
Many thanks Robert.
I think the L322 doors are stamped as a single piece, and the bits fastened on - probably using Voodoo !
Your Disco looks very tidy. I put some of those wheels on my Range Rover Classic, a few years ago.
I shall purloin some shoe wax from Morrisins, and at least do the rest of the trim that is good.
May finish up going to the dealers to try and find out how the trim comes off.
Thanks again.
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #113802 19th Mar 2012 12:35pm
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
once you order the new trim is becomes obvious how its held on, i changed mine a few months ago and recall it was quite simple. the door mirror needs to come off for a start then undo the window, the rubber that runs around the outside of the door is held into the trim your going to replace so need to come off aswel to reveal some screws, cant remember the exact way i did it but there no need to worry about it, i used wax oil under the new trim and under the rubber to protect it in future. its worth ordering the trim that goes up the back edge of the door on the outside aswell, mine was slightly corroded like the front section.
Post #113930 20th Mar 2012 1:00am
+1, not a hard job, quite satisfying though i recall... A series of small screws and rubber covers, but quite easy to do if your not too ham fisted with it...
Craig Thumbs Up
Post #113932 20th Mar 2012 1:14am
mjdronfield
Many thanks.
I shall have to follow RAVE for stripping down the inside of the door, ie door card off and the plastic inside trim with the tweeter on and go from there then.
Thanks again.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #114016 20th Mar 2012 12:34pm
mark, theres a video on the powerfuluk site re removing door cards, link in the wiki... .. ... - .- -.
Post #114020 20th Mar 2012 1:00pm
